0 Replies Latest reply on Aug 2, 2012 5:18 AM by mcallit82
    RH9 Batch Compile Failures
    mcallit82 Level 1
      I have a batch file set up to batch compile numerous projects one after the other for RoboHelp 9. The output is CHM format. When doing the compile, usually at least one project fails to completely compile and the log file shows only this information:
      Adobe (R) RoboHelp Project Command Line Compiler version
      Copyright (C) 2006-2007, Adobe Systems Incorporated and its licensors. All rights reserved.
      Project: C:\TechComm\SPIRIT\source\projects\directd\directd.xpj
      Layout: ssl_directd_hdi.
      Output: C:\TechComm\SPIRIT\output\help\directdhdi.chm.
      Scanning project for compilation....
      Scanning finished.
      Warning: No baggage file description.
      There are no files attached to the project. The baggage file contains some CHMs that were used for remote links, but they are not included in the project.
      Additionally, if I recompile this project using the batch file, it will build fine. How can I stop these initial failures? It's not just this project, but others will randomly not generate and the log file shows the same information.
