6 Replies Latest reply on Aug 3, 2012 2:01 PM by the_wine_snob
    Audio Gain Crash
    steverup50 Level 1
      I am using CS5 and everytime I use the Audio Gain, the program crashes. Both P2 and EX-1 files. Is there an update that fixes this?
      Steve
        • 1. Re: Audio Gain Crash
          the_wine_snob Level 9
          Can you post more details?
          This FAQ Entry will be helpful, in outlining what info would be useful: http://forums.adobe.com/thread/961741?tstart=0
          • 2. Re: Audio Gain Crash
            steverup50 Level 1
            I have a series of audio clips (VO) in one of my stereo tracks. They are wav files. When I select all of them or just one and go to Clip-Audio Options –Audio Gain, Premiere crashes. This happens every time.
            • 3. Re: Audio Gain Crash
              What is your OS?
              What are the specs. of your computer?
              What are the specs. of those WAV files?
              What is your Sequence Preset?
              • 4. Re: Audio Gain Crash
                steverup50 Level 1
                OS is Windows 7 Professional
                8GB Ram, 2.80 GHz, 64 bit
                WAV – 48 Khz, 16 bit Mono
                Sequence Preset – 1920x1080 30fps
                • 5. Re: Audio Gain Crash
                  steverup50 Level 1
                  Bill:
                  Can I ask another question aside from the Audio Gain….
                  In my timeline, I have a bunch of clips that were all shot in the same room under the same lighting conditions. I have to color correct these clips but they are scattered all over the timeline. When I color correct one clip, is there a way to save the settings, so for all the other clips, I can simply drag the saved settings onto them? Because they will all need the exact same color correction settings, is there a way to simply drag what I changed on the first clip to all the others?
                  Thanks, Steve
                  • 6. Re: Audio Gain Crash
                    For the CC settings, apply those Effects and their adjustments to one Clip. I would do this before applying any other Effects. When satisfied, with that adjusted Clip Selected, Rt-click on it, and choose Copy. Now, go through your Timeline, Selecting the other Clips (multiple Clips can be Selected by holding down the Shift key), and with them Selected, Rt-click on them, choosing Paste Attributes. You CC will be applied to each. Should you need to tweak the settings on a Clip-by-Clip basis, you can still adjust the CC.
