1. Re: Issue with Bridge CS6
JJMack Aug 4, 2012 6:44 AM (in response to Citizen Gallagher)Which OS are you using. If Windows check the properties of you Bridge shortcut to see if its point to CS6 bridge and also check your registry to see which bridge version is the default one. somethinf like
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\bridge.exe]
@="C:\\Program Files\\Adobe\\Adobe Bridge CS6 (64 Bit)\\bridge.exe"
"Path"="C:\\Program Files\\Adobe\\Adobe Bridge CS6 (64 Bit)"
2. Re: Issue with Bridge CS6
Citizen Gallagher Aug 4, 2012 7:11 AM (in response to JJMack)Yes I'm using Windows 7. Thanks I'll investigate. How do I change the default to CS6 if it isn't already.
Cheers
3. Re: Issue with Bridge CS6
JJMack Aug 4, 2012 8:16 AM (in response to Citizen Gallagher)If its not the CS6 Install did not work correctly you could just try to install CS6 again on top of CS6. If still bad edit shortcuts for the bridge to see if you can poit to the CS6 bridge and use regedit (be careful) to fix [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\bridge.exe]
If you installed CS6 beta you needed to un-install that first with a Adobe CS6 Beta cleaner before installing CS6.
http://helpx.adobe.com/creative-suite/kb/cs5-cleaner-tool-installation-problems.html
http://forums.adobe.com/message/4361731#4361731
Message was edited by: JJMack
4. Re: Issue with Bridge CS6
Citizen Gallagher Aug 4, 2012 9:10 AM (in response to JJMack)Nice one. Probably will do a re-install. Thanks for your help, much appreciated.
5. Re: Issue with Bridge CS6
katiearees Oct 8, 2012 6:59 PM (in response to Citizen Gallagher)I'm having this issue as well. CS5 has an .exe that continues to run even though I've installed CS6. When I go to Task Manager and select the "processes" tab, there is a Bridge.exe file for CS5 that is running. I right click this item and "end process" which then allows CS6 to work instead. Is there a way to make this file stop running automatically every time I restart my computer?
6. Re: Issue with Bridge CS6
Curt Y Oct 8, 2012 7:18 PM (in response to katiearees)Yes, you both have CS5 Bridge running in the background. You can quit program in the Task Manager, but to disable this feature go to Bridge edit/preferences/advance and uncheck "start Bridge at login".
