1 Reply Latest reply on Aug 7, 2012 8:10 PM by klcodanr85
    x-path query to get all versions of  a node at a given path in JSP
    tanuj004
      hi need a xpath query so that i can list all the versions of a selected node which can be used for restoring the version to that particular one??
        • 1. Re: x-path query to get all versions of  a node at a given path in JSP
          klcodanr85 Level 1
          I'm not sure about an xpath query (which was deprecated in JCR 2.0), but here's how you could use the JCR API to retrieve all of the versions from a path:
               * Returns all of the versions at the specified path as a List of Versions.
               * @param session
               *            the currect JCR session, must not be null
               * @param path
               *            the absolute path of the node to retrieve
               * @return the list of versions at the specified path
               * @throws UnsupportedRepositoryOperationException
               *             thrown if the node at the specified path is not versionable
               * @throws RepositoryException
               *             an unexpected exception occurs interacting with the JCR
               *             repository
              public List<javax.jcr.version.Version> getVersions(final Session session,
                  final String path) throws UnsupportedRepositoryOperationException,
                  RepositoryException {
              final List<Version> versions = new ArrayList<Version>();
              final VersionManager versionMgr = session.getWorkspace()
                  .getVersionManager();
              final VersionHistory versionHistory = versionMgr
                  .getVersionHistory(path);
              final VersionIterator versionIterator = versionHistory.getAllVersions();
              while (versionIterator.hasNext()) {
                  versions.add(versionIterator.nextVersion());
              return versions;
