Hi to all,
In my Java application, I'm using a text field and a panel to load flash files. I'm using JDIC 0.9.1 to load the flash files in the panel. The flash files are created by Flash CS4.
While running the application, I can't enter any value in the Text field, after minimize and maximize the application I can enter the values.
This problem happens after change the jre version from 1.6 to 1.7.
I'm getting the following exception while running the application.
org.jdesktop.jdic.init.JdicInitException: java.io.IOException: The filename, directory name, or volume label syntax is incorrect
at org.jdesktop.jdic.init.JdicManager.initBrowserNati ve(Unknown Source)
at org.jdesktop.jdic.browser.WebBrowser.<clinit>(Unkn own Source)
pls give me a solution.
Thanks in advance...:)
