0 Replies Latest reply on Aug 6, 2012 5:51 AM by Christophe_FR
    ALC-WKS-007-040
    Christophe_FR
      Hello,
      I have several applications hosted in AdobeLivecycle ES 2.5. They are started using workspace. They use "Assign Task" components. They are working quite well.
      But I have a problem while trying to view the first PDF of the workflow using the "audit" tab in workspace (for a process already started).
      The problem only happens on our DEV environnement. It is OK (the problem does not occur) in our Prod environnement.
      In the workspace of our DEV environnement, i have the following error "An error occurred creating the form (task 47035, form 0). (ALC-WKS-007-040)"
      When I look in the logfile, the error is then "ALC-WKS-005-028: A problem occurred in the Render Service.  Please review the render orchestration for this process."
      I use the default render process in AdobeLivecycle ES 2.5
      See the extract of the logfile below.
      Any idea which xmldata sax is complaining about ?
      Thank you for any help
      Christophe
      2012-08-06 14:01:53,099 ERROR [STDERR] [Fatal Error] :1:1: Content is not allowed in prolog.
      2012-08-06 14:01:53,099 WARN  [com.adobe.livecycle.augmentform.FormAugmenterService] Content is not allowed in prolog.
      2012-08-06 14:01:53,161 ERROR [STDERR] [Fatal Error] :1:1: Content is not allowed in prolog.
      2012-08-06 14:01:53,161 ERROR [com.adobe.formServer.FormServer] xmldata: Content is not allowed in prolog., cause: org.xml.sax.SAXParseException- Content is not allowed in prolog.
      2012-08-06 14:01:53,193 ERROR [com.adobe.workflow.AWS] An exception was thrown with name com.adobe.livecycle.formsservice.exception.RenderFormException message:xmldata: Content is not allowed in prolog., cause: org.xml.sax.SAXParseException- Content is not allowed in prolog. while invoking service FormsService and operation renderPDFForm and no fault routes were found to be configured.
      2012-08-06 14:01:53,193 ERROR [com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker] An exception was thrown with name com.adobe.livecycle.formsservice.exception.RenderFormException message:xmldata: Content is not allowed in prolog., cause: org.xml.sax.SAXParseException- Content is not allowed in prolog. while invoking service FormsService and operation renderPDFForm and no fault routes were found to be configured.
      2012-08-06 14:01:53,208 ERROR [com.adobe.workflow.AWS] An exception was thrown with name com.adobe.livecycle.formsservice.exception.RenderFormException message:xmldata: Content is not allowed in prolog., cause: org.xml.sax.SAXParseException- Content is not allowed in prolog. while invoking service FormsService and operation renderPDFForm and no fault routes were found to be configured.
      2012-08-06 14:01:53,271 INFO  [org.jboss.resource.connectionmanager.CachedConnectionManager] Closing a connection for you.  Please close them yourself: org.jboss.resource.adapter.jdbc.WrappedConnection@33867b23
      java.lang.Throwable: STACKTRACE
       at org.jboss.resource.connectionmanager.CachedConnectionManager.registerConnection(CachedConnectionManager.java:290)
       at org.jboss.resource.connectionmanager.BaseConnectionManager2.allocateConnection(BaseConnectionManager2.java:417)
       at org.jboss.resource.connectionmanager.BaseConnectionManager2$ConnectionManagerProxy.allocateConnection(BaseConnectionManager2.java:842)
       at org.jboss.resource.adapter.jdbc.WrapperDataSource.getConnection(WrapperDataSource.java:88)
       at com.adobe.idp.docmanager.DocManagerUtil.getDataBaseConnection(DocManagerUtil.java:104)
       at com.adobe.idp.docmanager.NaiveDBBackendImpl$Statements.initConn(NaiveDBBackendImpl.java:163)
       at com.adobe.idp.docmanager.NaiveDBBackendImpl$Statements.getSelectStatement(NaiveDBBackendImpl.java:170)
       at com.adobe.idp.docmanager.NaiveDBBackendImpl.read(NaiveDBBackendImpl.java:390)
       at com.adobe.idp.DocumentDBBackend.read(DocumentDBBackend.java:98)
       at com.adobe.idp.DocumentFileID.read(DocumentFileID.java:126)
       at com.adobe.idp.Document.getInputStream(Document.java:2007)
       at com.adobe.livecycle.augmentform.FormAugmenterService.addFieldsToData(FormAugmenterService.java:431)
       at com.adobe.livecycle.augmentform.FormAugmenterService.insertWorkflowXfoData(FormAugmenterService.java:269)
       at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
       at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
       at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
       at java.lang.reflect.Method.invoke(Method.java:597)
       at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.java:118)
       at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor.java:140)
       at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptorChainImpl.java:60)
       at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassivationInterceptor.java:53)
       at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(TransactionInterceptor.java:74)
       at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTransactionCMTAdapterBean.java:357)
       at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(EjbTransactionCMTAdapterBean.java:227)
       at sun.reflect.GeneratedMethodAccessor446.invoke(Unknown Source)
       at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
       at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionContainer.java:237)
       at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:158)
       at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstanceInterceptor.java:169)
       at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
       at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
       at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:378)
       at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:181)
       at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
       at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
       at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor.java:138)
       at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
       at org.jboss.ejb.Container.invoke(Container.java:960)
       at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
       at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
       at $Proxy161.doSupports(Unknown Source)
       at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:104)
       at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInterceptor.java:72)
       at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStrategyInterceptor.java:55)
       at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateInterceptor.java:37)
       at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterceptor.java:165)
       at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
       at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:115)
       at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
       at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessageReceiver.java:93)
       at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:209)
       at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispatcher.java:66)
       at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
       at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:886)
       at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker.java:347)
       at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:158)
       at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew(EjbTransactionCMTAdapterBean.java:299)
       at sun.reflect.GeneratedMethodAccessor216.invoke(Unknown Source)
       at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:404)
       at $Proxy161.doRequiresNew(Unknown Source)
       at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:143)
       at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterceptor.java:188)
       at com.adobe.idp.taskmanager.dsc.service.TaskManagerServiceImpl.renderForm(TaskManagerServiceImpl.java:4605)
       at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:184)
       at com.adobe.idp.taskmanager.dsc.client.TypedTaskManagerService.invokeWithRetry2(TypedTaskManagerService.java:159)
       at com.adobe.idp.taskmanager.dsc.client.TypedTaskManagerService.invokeWithRetry(TypedTaskManagerService.java:147)
       at com.adobe.idp.taskmanager.dsc.client.TypedTaskManagerService.callRenderService(TypedTaskManagerService.java:1441)
       at com.adobe.workspace.tasks.TaskActions.render(TaskActions.java:767)
       at flex.messaging.services.remoting.adapters.JavaAdapter.invoke(JavaAdapter.java:421)
       at flex.messaging.services.RemotingService.serviceMessage(RemotingService.java:183)
       at flex.messaging.MessageBroker.routeMessageToService(MessageBroker.java:1406)
       at flex.messaging.AsyncMessageBroker.routeMessageToService(AsyncMessageBroker.java:571)
       at flex.messaging.endpoints.AbstractEndpoint.serviceMessage(AbstractEndpoint.java:1005)
       at flex.messaging.endpoints.amf.MessageBrokerFilter.invoke(MessageBrokerFilter.java:103)
       at flex.messaging.endpoints.amf.LegacyFilter.invoke(LegacyFilter.java:158)
       at flex.messaging.endpoints.amf.SessionFilter.invoke(SessionFilter.java:44)
       at flex.messaging.endpoints.amf.BatchProcessFilter.invoke(BatchProcessFilter.java:67)
       at flex.messaging.endpoints.amf.SerializationFilter.invoke(SerializationFilter.java:165)
       at flex.messaging.endpoints.BaseHTTPEndpoint.service(BaseHTTPEndpoint.java:293)
       at flex.messaging.MessageBrokerServlet.service(MessageBrokerServlet.java:364)
       at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
       at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
       at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
       at com.adobe.workspace.events.RemoteEventClientLifeCycle.doFilter(RemoteEventClientLifeCycle.java:152)
       at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
       at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
       at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
       at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
       at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.java:179)
       at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
       at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
       at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
       at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:157)
       at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
       at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:241)
       at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:853)
       at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:579)
       at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1513)
       at java.lang.Thread.run(Thread.java:662)
      2012-08-06 14:01:53,286 ERROR [com.adobe.workspace.tasks.TaskActions] ALC-WKS-005-028: A problem occurred in the Render Service.  Please review the render orchestration for this process.
      com.adobe.idp.taskmanager.dsc.client.task.TaskManagerException: Error Invoking render Operation For (taskId, formId):(46119 ,0).  Error Message is:
       at com.adobe.formServer.Controller.tweakXMLData(Controller.java:364)
       at com.adobe.formServer.Controller.render(Controller.java:126)
       at com.adobe.formServer.FormServer.renderForm(FormServer.java:214)
       at com.adobe.formServer.FormServer.renderForm(FormServer.java:281)
       at com.adobe.formServer.docservice.FormsDocService.renderForm(FormsDocService.java:571)
       at com.adobe.formServer.docservice.FormsDocService.renderForm(FormsDocService.java:485)
       at com.adobe.formServer.docservice.FormsDocService.renderPDFFormCommonCaller(FormsDocService.java:179)
       at com.adobe.formServer.docservice.FormsDocService.renderPDFForm(FormsDocService.java:145)
       at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequired(EjbTransactionCMTAdapterBean.java:274)
       at sun.reflect.GeneratedMethodAccessor218.invoke(Unknown Source)
       at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:350)
       at $Proxy161.doRequired(Unknown Source)
       at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:129)
      2012-08-06 14:01:53,286 INFO  [STDOUT] [LCDS][ERROR] Exception when invoking service 'remoting-service': flex.messaging.MessageException: ALC-WKS-005-028: A problem occurred in the Render Service.  Please review the render orchestration for this process.
        incomingMessage: Flex Message (flex.messaging.messages.RemotingMessage)
          operation = render
          parameters = [20D68292-C64A-102E-95C3-000084A8C8C6, 46119, 0, ASObject(2142754825){acrobatVersion=9.4.5, acroClientType=}]
          clientId = 1EC6F5D0-2D0A-A021-DAEA-983FDE78668E
          destination = task-actions
          messageId = 1547C2B0-CF09-DDA1-E139-FBD011C8C31A
          timestamp = 1344254513021
          timeToLive = 0
          body = null
          hdr(DSId) = 1EC1E133-A21C-418C-CD8E-EBFEF8057D07
          hdr(DSEndpoint) = workspace-polling-amf
        Exception: flex.messaging.MessageException: ALC-WKS-005-028: A problem occurred in the Render Service.  Please review the render orchestration for this process.
       at com.adobe.workspace.AssemblerUtility.createMessageException(AssemblerUtility.java:412)
       at com.adobe.workspace.tasks.TaskActions.render(TaskActions.java:800)
      Caused by: com.adobe.idp.taskmanager.dsc.client.task.TaskManagerException: Error Invoking render Operation For (taskId, formId):(46119 ,0).  Error Message is:
       ... 38 more
