0 Replies Latest reply on Aug 6, 2012 5:50 PM by BorisTs.
    Rendering LiveCycle PDF forms using ASP.NET and MS SQL Server
    BorisTs. Level 1
      What's the best way to populate PDF form created in LiveCycle designer using ASP.NET and SQL server?
      After this form is generated on a server, I need to send it to a client and present it in a browser. Please note that this is a static form.
      I'm looking for the following process:
      1. Create a PDF form template using Adobe LiveCycle ES.
      2. Using ASP.NET application bind this template with fields from MS SQL Server
      3. Save PDF result in database as a binary object (VARCHAR(MAX))
      4. Send PDF to a client's browser
      I was trying to use Acrobat SDK for static forms (FillFormCS) using XML data biding but I'm wondering if there's a better solution available to render PDF in .NET object, save it as a stream and send it back to the client. FillFormCS requires to save a PDF template with a new name on local disk first before binding form data.
      Thank you in advance!
      Boris
