0 Replies Latest reply on Aug 7, 2012 3:12 AM by gotroots2
    Blank webpage when run
    gotroots2 Level 1
      For some reason I am getting a blank webpage when I run a project locally. Never had this kind of problem before. This problem has just suddenly appeared. I have looked for a solution on the web but non so far solved the issue.
      This is what Ihave tried already:
      When I copy the path and paste it into another browser then the webpage will display, but this is not a satifactory solution.
      I have also added under project/properties/Flex Compiler -use-network=false as an additional compiler argument, again no effect.
      I am using Flash Builder 4.5
      Anyone got a suggestion which might help.
