This content has been marked as final.
Show 4 replies
1. Re: Local vs Internet IP, MU doesn't know
Newsgroup_User Feb 16, 2008 5:56 AM (in response to alexcy27)"I am guessing is because it is trying to find that IP over the internet
instead on my local network?"
I don't believe this is correct. If the client, server and SQL server(?)
are all on the same LAN, then any communications should stay local.
Are you sure the application you are trying to run works? Is it
something you are creating yourself, or are you trying to use a packaged
application? Are you running any firewalls that block ports?
Director has no problem making client/server connections over a local
network. Since the client and server are both on the same LAN, the
router should route all message appropriately.
Can you provide more details? It would be useful in providing you help. -
2. Re: Local vs Internet IP, MU doesn't know
alexcy27 Feb 16, 2008 10:15 AM (in response to alexcy27)Thank you for the reply.. The problem was the windows firewall at the end... Somehow it got turned ON and blocking the connection to the server.. You response put me on the right track and made me look at the firewall..
Thanks again,
Alex -
3. Re: Local vs Internet IP, MU doesn't know
Gerarrdinho Nov 7, 2009 6:47 AM (in response to alexcy27)I didn't understand the main differnce between Local IP & Internet IP
pls I have to know
give us deep explanation
4. Re: Local vs Internet IP, MU doesn't know
pls I have to know
Gerarrdinho,
1. Please start your own thread instead of taking over another one in this forum.
2. Is this information needed for a Director related project or just information you are looking for in general?
