1. Re: Menu Highlight not showing in Burnt DVD
Stan Jones Aug 8, 2012 8:14 AM (in response to dpDesignz)Please post a screenshot of your flowchart.
2. Re: Menu Highlight not showing in Burnt DVD
dpDesignz Aug 8, 2012 1:44 PM (in response to Stan Jones)Also please see the following link for screenshots for the menu, menu-active, button-routing, menu-settings, menu-layers, and the menu-colour-set
3. Re: Menu Highlight not showing in Burnt DVD
Stan Jones Aug 8, 2012 2:48 PM (in response to dpDesignz)The end action on your main menu appears to be itself. Change it to Stop and see if that makes a difference. An odd problem was solved by another user with the same issue:
4. Re: Menu Highlight not showing in Burnt DVD
dpDesignz Aug 8, 2012 7:29 PM (in response to Stan Jones)Hmm. Thanks for the idea but still a no go.
5. Re: Menu Highlight not showing in Burnt DVD
Stan Jones Aug 8, 2012 7:55 PM (in response to dpDesignz)I see nothing that should be a problem.
I would add a template menu, keep two buttons only, one to go back to a menu and the other to link to some timeline, (link it from some button on the main menu), change nothing in it otherwise, and see if those highlights show up.
Any reason for the =2 and =3, rather than something else? Any history of issues? On a mac?
6. Re: Menu Highlight not showing in Burnt DVD
dpDesignz Aug 8, 2012 8:20 PM (in response to Stan Jones)Ok so did that and the sub-menu highlights worked. . Used the Crib Menu HD.
Still nothing on the main though
No reason for =2 or =3. I did have another colour which was =1 but got rid of those and just haven't changed these. But still had issue then as well.
I'm running a massive Windows 7 PC.
One interesting note though. I export the Crib Menu HD and my Menu and the Crib one comes up large and fine, but mine comes up with the name and then in square bracket [scaled]. I tried duplicating the layers between the files and mine is WAY smaller than the crib one is
7. Re: Menu Highlight not showing in Burnt DVD
dpDesignz Aug 8, 2012 9:18 PM (in response to dpDesignz)Ok I tried changing the menu type to Blank HD. This is my process for creating the DVD
1) Create a Blank Menu HD
2) Add AE comp to project
3) Link Video and Audio in "motion" tab to AE comp file
4) Set loop Point
5) Set Aspect ratio to 16:9
6) Export Menu to Photoshop and add buttons
7) Set link for each button
8) Change Colour Set to my custom menu set
9) Untick Automatically Route Buttons and set route
And that's it
Still not working, and now when I do a build preview, the buttons aren't aligned the same as the preview when "show selected subpicture highlight" is on or the PSD file
8. Re: Menu Highlight not showing in Burnt DVD
Stan Jones Aug 9, 2012 6:56 AM (in response to dpDesignz)What is the pixel size and par of the ae comp?
What do you mean by "export to ps" - vs "edit in photoshop"?
Edit: Good troubleshooting steps!
9. Re: Menu Highlight not showing in Burnt DVD
dpDesignz Aug 9, 2012 1:05 PM (in response to Stan Jones)Hey the pixel size is 1050x576, PAR is Square Pixels FAR 175:96 (1.82)
It's the PAL D1/DV Widescreen Square Pixel Preset
Sorry, yes edit in Photoshop.
10. Re: Menu Highlight not showing in Burnt DVD
Stan Jones Aug 9, 2012 1:30 PM (in response to dpDesignz)In some DVD projects, odd pixel size menus resulted in highlights "disappearing." These were usually thin lines, and I came to believe that EN was calculating highlight positions based on some anchor point - and unexpected pixel sizes resulted in problems.
I wonder if a mismatch between the EN project setting for default transcode (what it uses for menus) or the like could create a problem.
I suspect a template menu that you bring into your project is 1920x1080 square.
11. Re: Menu Highlight not showing in Burnt DVD
dpDesignz Aug 9, 2012 2:27 PM (in response to Stan Jones)Hmm. Like I said though, I've burnt a DVD with the same settings before. Same comp settings and same menu settings.
I'm using the Blank Menu HD, I have tried the Blank Menu SD, I wonder if using the Blank Menu Wide would change anything. I haven't tried that one yet. Will let you know.
12. Re: Menu Highlight not showing in Burnt DVD
Stan Jones Aug 9, 2012 2:45 PM (in response to dpDesignz)I'm sorry; I forgot you were doing DVD when you referred to using an HD menu. Stick with the format and appropriate size for your project.
I know it has worked before, but it is not now, so we have to keep an open mind. Ha, ha!
I could not replicate the "disappearing highlights" problem for a user some time ago, until I hit the right combination of highlight size and location on the screen. But I don't think that ever affected all highlights in the menu.
13. Re: Menu Highlight not showing in Burnt DVD
dpDesignz Aug 9, 2012 3:00 PM (in response to Stan Jones). Ok will try the wide when I'm finished work and see if that changes anything
Just in comment, in my screen shot for the active state, the white outlines are 6px, and the buttons are 50px*about 220px
14. Re: Menu Highlight not showing in Burnt DVD
dpDesignz Aug 15, 2012 10:23 PM (in response to dpDesignz)Ok took me a week. My bad. Just tried a Wide menu and still no luck. so tried every size menu I can and zilch.
