1. Re: Cutting graphic frames in pieces
GoaliGrlTilDeath Aug 8, 2012 11:38 AM (in response to Politikarvackert)I had never used the scissors before but I was just playing with them now to try and find an answer... It looks like they slice the shape into two open paths. In order to cut those two new shapes I had to close the paths. So grab the pen tool, click on the end of half-circle 1, then click on the other end of half-circle 1 to close the path. Visually it looks the same but is now a closed path that can be cut again with the scissiors. You'll have to do this with each part of the circle you need to slice.
Not sure if this is the only solution, but it seems to work. cumbersome, yes, but it might work until you find a better solution!
2. Re: Cutting graphic frames in pieces
Politikarvackert Aug 8, 2012 12:15 PM (in response to GoaliGrlTilDeath)Thanks but I can't make it work. Maybe I'm doing something wrong:
1. I select a half-circle (made by vertically cutting a full circle into two)
2. Using the pen tool, I first select one of the end points, in this case at the top
3. I then select the other end point, at the bottom.
The result is a strange shape, like a deformed pear or something...
3. Re: Cutting graphic frames in pieces
P Spier Aug 8, 2012 1:11 PM (in response to Politikarvackert)First off, I have no problem using the scissor tool to cut an open path made from cutting the circle. What version of ID are you using?
This is becasue the two end points you selected have symmetrical control handles. You need to use the Convert Direction Point Tool (under the Pen Tool, or just hold the Alt/Opt key with the Pen tool active) to collapse the handles for the straight side.
Also, you can select the two end points of a path and use Object > Paths > Join rather than the Pen tool to close it.
4. Re: Cutting graphic frames in pieces
Politikarvackert Aug 8, 2012 1:37 PM (in response to P Spier)Thanks, I found the Covert Direction Tool and started using it. It works but a bit complex doing it on every piece (I'm making lots). Will try the other option you mention.
I'm using ID 6, version 8.0
5. Re: Cutting graphic frames in pieces
P Spier Aug 8, 2012 1:41 PM (in response to Politikarvackert)You'd really find it much easier to make these shapes using the pathfinder in Illustrator, which has a divide function that is not in the ID pathfinder.
There was a similar thread about a week ago with a few suggestions for "easy" ways to use ID's tools to make pie chats, if you have to.
6. Re: Cutting graphic frames in pieces
peter at knowhowpro Aug 9, 2012 7:47 AM (in response to P Spier)Hi, Peter S!
I've enjoyed your typos for a long time, but I enjoy talking about pie even more. This one gave me an idea about starting a pie chat room.<G>
Regards,
Peter
_______________________
Peter Gold
7. Re: Cutting graphic frames in pieces
P Spier Aug 9, 2012 7:59 AM (in response to peter at knowhowpro)Oh, geez.
8. Re: Cutting graphic frames in pieces
peter at knowhowpro Aug 9, 2012 8:17 AM (in response to P Spier)Peter Spier wrote:
Oh, geez.
I hope this isn't an intentional typo for "geezer."
Regards,
Peter
Peter Gold
KnowHow ProServices
9. Re: Cutting graphic frames in pieces
P Spier Aug 9, 2012 8:21 AM (in response to peter at knowhowpro)No, I meant cheese, which you also can cut into wedges, like pies.
or did I?
10. Re: Cutting graphic frames in pieces
[Jongware] Aug 9, 2012 8:34 AM (in response to P Spier)http://forums.adobe.com/message/4291658#4291658 ("A script to make pies, and more.")
Thus the "and more" also includes pizza and cheese!
