1 Reply Latest reply on Aug 8, 2012 7:02 PM by Ned Murphy
    External SWF dissapears afte sometime
    separm@yahoo.com
      Hi There!
      I have a preloader to preload a SWf file, everything works fine, except, when I run html file on any browser, external swf file dissapears after 1-2 minutes,
      basically, I put preloader (swf file), on html code, and preload the external swf.
      this is the code:
      import flash.geom.*
      import flash.display.*
      var loadurl:String = "external.swf";
      var nDepth:Number = 0;
      var nWidth:Number = 200;
      var nHeight:Number = 20;
      var cLoader:MovieClipLoader = new MovieClipLoader();
      var oListener:Object = {onLoadInit:onContentLoaded};
      var mcLoader:MovieClip = this.createEmptyMovieClip("Loader_MC", 0);
      var mcContent:MovieClip = this.createEmptyMovieClip("Content_MC", 1);
      var cMatrix:Matrix = new Matrix();
      cLoader.addListener(oListener);
      txtPercLoad = mcLoader.createTextField("PercLoad_TXT", nDepth++, 0, 0, nWidth, nHeight);
      mcContent._alpha = 0;
      mcContent._lockroot = true;
      mcLoader._x = Stage.width/2 - mcLoader._width/2;
      mcLoader._y = Stage.height/2 - mcLoader._height/2;
      txtPercLoad._x = mcLoader._width/2 - txtPercLoad._width/2;
      txtPercLoad._y = mcLoader._height/2 - txtPercLoad._height/2;
      cLoader.loadClip(loadurl, mcContent);
      _root.onEnterFrame = function()
         var nBytesLoaded:Number = mcContent.getBytesLoaded();
         var nBytesTotal:Number = mcContent.getBytesTotal();
         var nPercLoaded:Number = Math.round(nBytesLoaded / nBytesTotal * 100);
         if(nPercLoaded > 0)
            SetTextFormat(txtPercLoad, nPercLoaded.toString() + "%");
      function onContentLoaded(Void):Void
         SetTextFormat(txtPercLoad, "100%");
         cLoader.removeListener(oListener);
         delete _root.onEnterFrame;
         delete oListener;
         delete cLoader;
            //trace(_root + "::onContentLoaded::_root.onEnterFrame");
            var nInc:Number = 5;
            mcLoader._alpha -= nInc;
            mcContent._alpha += nInc;
            if(mcLoader._alpha <= 100) {mcLoader.removeMovieClip();};
      function SetTextFormat(txtField:TextField, sText:String)
         var txtFmt:TextFormat = new TextFormat();
         sText = "Loading Content " + sText;
         txtFmt.font = "Arial";
         txtFmt.align = "center";
         txtFmt.size = 12;
         txtFmt.color = 0xff0000;
         //txtFmt.bold = true;
         txtField.selectable = false;
         txtField.text = sText;
         txtField.setTextFormat(txtFmt);
         txtFmt = null;
      Please let me know what I am doing wrong? thanks in advance
        • 1. Re: External SWF dissapears afte sometime
          If you keep an eye on the value of mcContent._alpha, you'll see that because you never shut off that second onEnterFrame function, the _alpha property continues to go up until it reaches a maximum and then flips negative, which means it goes invisible.  I confirmed this with running your code.
          I don't know what the limit is.  In Actionscript, when a number limit is reached it is common for it to advance to its opposite limit - basically a looped numeric system.
