2 Replies Latest reply on Jan 21, 2014 5:50 AM by jarema
    Turn of Undo/History?
    benjaminmueller_burda Level 1
      is it possible to turn of History/Undo in InCopy/InDesign while modifying the content with CSSDK? It seems that InDesign could be A LOT faster if it wouldn't try to remember whatever the code does via scripting.
      Thanks for your help!
      Regards
      Benjamin
        • 1. Re: Turn of Undo/History?
          Harbs. Level 6
          Not really, but you can use UndoModes to collapse all changes into a single undo...
          • 2. Re: Turn of Undo/History?
            jarema
            a little old topic but I actualy got the same question.
            I am automating InDesign (CS5.5 - CC) using VB.NET compiled as exe.
            the exe is started from SDK plug-in.
            For this reason the UndoMode is not an option because I do not use DoScript.
            Saving document while processing it to clear Undo is also too slow.
            I am asking myself if it would be possible to create small scriptable plug-in which could be accessed from VB.NET to clear undo each time it is called?
            any suggestions?
            thx in advance
            mariusz
