0 Replies Latest reply on Aug 9, 2012 8:59 AM by mipmater
    Modify the xml generated by a PDF form
      I want to create PDF forms (via livecycle ES2) from tables of an Access database.
      When I generate an XML file from the PDF forms, and I try to inject them into my Access database, it does not work.
      If I replace the tag data <dataroot>, with the one found in an Access xml export it works. Is it possible from Livecycle ES2 to modify the structure of the xml output?
      For example, can I replace <dataroot generated=""> by <dataroot xmlns:od="urn:schemas-microsoft-com:officedata"......> ?
