4 Replies Latest reply on Aug 9, 2012 4:48 PM by Marc Braun
    Exported file wrong size
    Marc Braun
      My source file and export file are both set to 720x486 yet when I play the movie back it shows up as 720x488 and there is a green bar across the very bottom?
        • 1. Re: Exported file wrong size
          Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
          What is a CODEC... a Primer http://forums.adobe.com/thread/546811
          What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
          Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing... including your project and export settings
          http://forums.adobe.com/thread/592070?tstart=30
          For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
          For Mac http://mediainspector.massanti.com/
          • 2. Re: Exported file wrong size
            Marc Braun Level 1
            Here is a report of the outputted file
            • * * MediaInspector for Mac - Version 2.0, build 896
            • * * ©2012 by Diego Massanti
            • * * MediaInfo Lib by Jerome Martinez
            • * * Raw File Report for GreenwaldIntro_1.mp4
            General
            Complete name                    :
            Format                           : MPEG-4
            Format profile                   : Base Media / Version 2
            Codec ID                         : mp42
            File size                        : 55.2 MiB
            Duration                         : 2mn 25s
            Overall bit rate                 : 3 189 Kbps
            Encoded date                     : UTC 2012-08-09 16:15:36
            Tagged date                      : UTC 2012-08-09 16:15:37
            �TIM                             : 00:00:00:00
            �TSC                             : 30
            �TSZ                             : 1
            Video
            Format                           : AVC
            Format/Info                      : Advanced Video Codec
            Format profile                   : Main@L3.1
            Format settings, CABAC           : Yes
            Format settings, ReFrames        : 3 frames
            Codec ID                         : avc1
            Codec ID/Info                    : Advanced Video Coding
            Duration                         : 2mn 25s
            Bit rate mode                    : Variable
            Bit rate                         : 2 995 Kbps
            Width                            : 720 pixels
            Height                           : 488 pixels
            Display aspect ratio             : 4:3
            Frame rate mode                  : Variable
            Frame rate                       : 30.000 fps
            Minimum frame rate               : 30.000 fps
            Maximum frame rate               : 30.030 fps
            Standard                         : NTSC
            Color space                      : YUV
            Chroma subsampling               : 4:2:0
            Bit depth                        : 8 bits
            Scan type                        : Interlaced
            Scan order                       : Bottom Field First
            Bits/(Pixel*Frame)               : 0.284
            Stream size                      : 51.8 MiB (94%)
            Language                         : English
            Tagged date                      : UTC 2012-08-09 16:15:36
            Audio
            Format                           : AAC
            Format/Info                      : Advanced Audio Codec
            Format profile                   : LC
            Codec ID                         : 40
            Duration                         : 2mn 25s
            Bit rate                         : 192 Kbps
            Maximum bit rate                 : 254 Kbps
            Channel(s)                       : 2 channels
            Channel positions                : Front: L R
            Sampling rate                    : 48.0 KHz
            Compression mode                 : Lossy
            Stream size                      : 3.28 MiB (6%)
            Language                         : English
            Also a screen shot of output setting from Premiere
            __
            Marc Braun
            330-217-3252
            marc@braunphotographics.com
            www.braunphotographics.com
            • 3. Re: Exported file wrong size
              Greg Baber Adobe Employee
              MPEG-4 files have to have pixel ratios that are divisible by 8.  480 is OK, as is 488.  486 does not meet this requirement, which is why it's being forced to 488.
              Premiere does not force this, but the file container protocol does.
              • 4. Re: Exported file wrong size
                Marc Braun Level 1
                Trhanks for the reply guess I¹ll output ay 480 and see what happens
                __
                Marc Braun
                330-217-3252
