1 Reply Latest reply on Aug 19, 2012 5:25 AM by prasaxen
    Assign task with use a document variable
    kc_chaitu Level 2
        if i'm assigning a pdf document in assign task operation with use a document variable instead of application asset, I see the same old blank form after user submits the form.
      what ever typed in the form is not seen in the output variable assigned in Assign user task.
      If I use application asset and provide input xml, then I could see the filled form as output when user submits.
      What should I do to get the filled data in the form?
      Note: Reason for using document variable is I want to dynamically assign the form created in the process to assign task instead of getting from repository.
      Highly appreciate your assistance.
      kc
