6 Replies Latest reply on Jun 24, 2013 1:07 AM by snayakar
    CQ5.5 ecommerce integration
    gshanky
      I am working on integrating Hybris with CQ ecommerce. I am following the documentation on - http://dev.day.com/docs/en/cq/current/ecommerce/eCommerce-framework.html
      However one of the steps is to import the catalog from Hybris into CQ through the Hybris catalog importer - http://localhost:4502/etc/importers/hybris.html
      When I open this Hybris catalog importer, I am getting a blank page. Not sure if I have missed anything.
      Any suggestions?
        • 1. Re: CQ5.5 ecommerce integration
          Sham HC Level 7
          For the property jsLibs at [0] please add "cq.commerce" before "cq.commerce.hybris" and verify.
          [0]   /etc/importers/hybris
          • 2. Re: CQ5.5 ecommerce integration
            gshanky Level 1
            That solved it. Thanks!
            • 3. Re: CQ5.5 ecommerce integration
              Mantas2012
              Hello gshanky,
              Did you do any specific configuration before importing the catalog into CQ?
              I started a discussion but so far no one has replied to me: http://forums.adobe.com/thread/1132522?tstart=0
              Thanks in advance for your help.
              Best,
              Mantas2012
              • 4. Re: CQ5.5 ecommerce integration
                gshanky Level 1
                Hi Mantas2012,
                Based on your msg, it seems like you are trying to import the same catalog into a different location. And probably the ones that did not complain are due to missing page references. The rest of the products have a reference to existing pages in a different location - most probably /content/geometrixx-outdoors. And since you are trying to copy to Geo-4, you are getting these errors.
                These errors should go away if you were to remove /etc/commerce/products/geometrixx-outdoors node and startover again. This also means that as of now you could use a catalog for only one CQ site per instance.
                • 5. Re: CQ5.5 ecommerce integration
                  Mantas2012 Level 1
                  Thank you so much, gshanky . It worked exactly as expected.
                  Sorry it took me a while to reply, I had several proejcts to work on and I test this  right away.
                  Best,
                  Mantas2012
                  • 6. Re: CQ5.5 ecommerce integration
                    snayakar Level 1
                    Hi Guys,
                    I am refering to GEOMetrixx-Outdoors project for building eCommerce fucntionality in our project.
                    Currently we are integrating with an ERP system to fetch the Product details.
                    Now I need to store all the Product data from ERP system in to our CRX  under etc/commerce/products/<myproject> folder structure.
                    Do I need to create a csv file structure as explained in the geometrixx-outdoors project  and place it exactly the way they have mentioned in the documentation? By doing this the csvimporter will import the data in to CRX and creates the Sling:folder and nt:unstructured nodes in to CRX?
                    Please guide me  which is this best practice to integrate the external eCommerce data in to CQ system to build eCommerce projects?
                    Are there any other best practices ?
                    Your help in this regard is really appreciated.
