2 Replies Latest reply on Aug 13, 2012 12:53 AM by Mario Wündsch
    continuous integration of flex mobile app not working
    Mario Wündsch
      Hello,
      we are using Adobe® Flash® Builder™ 4.6 Premium to develope Mobile Apps. Now we need a continious integration (linke Jenkins/Hudson) base on a maven (or ant ) build to run tests and packing the apps automatically.
      But a lot of time was spent to create a working pom.xml, but it's working.
      Can anyone help us, with a working example?
      thx.
      Mario
        • 1. Re: continuous integration of flex mobile app not working
          BBlommers
          I do not have a working example at hand atm, but:
          Could you post the pom.xml?
          Also, please clarify what exactly is not working.
          • 2. Re: continuous integration of flex mobile app not working
            Mario Wündsch Level 1
            hi,
            there are a lot of strange things and questions with my maven build. I have spend a lot of time of reading homepages and manuals. Here are some of them:
            1. Where I get the 4.6. flex sdk dependencies?
            2. Is there a correct way to add deps which are not in den openSource sdk like "fiber"?
            3. How to build release apps for iOS and android?
            4. How can a add some images?
            5. For my generated Services (extendsHTTPServiceWrapper) I must add the fiber dep. But now maven says: "ERROR] Unable to resolve resource bundle "fiber" for locale "en_US"."
            thx for the help
            Now my current pom.xml is a mixture of a lot of repositories, deps and plugins. Here is it:
            <?xml version="1.0" encoding="UTF-8"?>
            <project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
            xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
            <modelVersion>4.0.0</modelVersion>
                      <groupId>com.mwd-systems</groupId>
            <artifactId>rga</artifactId>
            <version>1.0-SNAPSHOT</version>
            <packaging>swf</packaging>
                      <name>test Flex</name>
            <properties>
              <flexmojos.version>4.1-beta</flexmojos.version>
              <!-- <flexmojos.version>4.0-RC2</flexmojos.version> -->
              <!-- <flexmojos.version>4.0-beta3</flexmojos.version> -->
              <!-- <flexmojos.version>3.1.0</flexmojos.version> -->
              <!-- <flex.sdk.version>4.5.0.20967</flex.sdk.version> -->
              <flex.sdk.version>4.5.1.21328</flex.sdk.version>
              <!-- <flex.sdk.version>4.5.0.17855</flex.sdk.version> -->
              <!-- <flex.sdk.version>4.6.0.23201</flex.sdk.version> -->
            </properties>
            <build>
              <sourceDirectory>src</sourceDirectory>
              <testSourceDirectory>test</testSourceDirectory>
              <resources>
              <resource>
              <directory>resources</directory>
              </resource>
              </resources>
              <plugins>
              <plugin>
                                                    <groupId>org.sonatype.flexmojos</groupId>
                                                    <artifactId>flexmojos-maven-plugin</artifactId>
                                                    <version>${flexmojos.version}</version>
              <extensions>true</extensions>
              <configuration>
              <sourceFile>rga.mxml</sourceFile>
              <compilerWarnings>
              <warn-no-constructor>false</warn-no-constructor>
              </compilerWarnings>
              <debug>true</debug>
              <coverage>true</coverage>
              <coverageProvider>cobertura</coverageProvider>
              <coverageReportFormat>html</coverageReportFormat>
              </configuration>
              </plugin>
              <plugin>
                                                    <groupId>com.yelbota.plugins</groupId>
                                                    <artifactId>adt-maven-plugin</artifactId>
              <version>1.0.3</version>
              <executions>
              <execution>
        <goals>
        <goal>package</goal>
        </goals>
              </execution>
              </executions>
              <configuration>
              <sdkVersion>3.3</sdkVersion>
                                                              <target>ipa-ad-hoc</target>
                                                              <keystore>data/ipa-certificate.p12</keystore>
                                                              <storepass>!!!THISISSECRET!!!</storepass>
              <!-- Required for ipa* targets -->
              <provisioningProfile>data/RGA_Profile.mobileprovision</provisioningProfile>
              <!-- Optional. Application descriptor. By default is src/main/resources/application-descriptor.xml -->
                                                              <descriptor>src/rga-app.xml</descriptor>
              <!-- Optional. Replaces versionNumber in application descriptor. Useful
        for CI. 0.0.0 by default. -->
              <versionNumber>${build.number}</versionNumber>
              <!-- Optional. Replaces versionLabel in application descriptor. ${project.version}
        by default. -->
              <versionLabel>${project.version}</versionLabel>
              <!-- By default includes lookedup in target/classes directory. Usualy
        maven-resources-plugin copy here content of src/main/resources. You can change
        this behaviour by setting <includesRoot> property. -->
              <includes>
              <!-- <include>icons</include> -->
              <include>images</include>
              </includes>
              </configuration>
              </plugin>
              </plugins>
            </build>
            <dependencies>
              <dependency>
                                          <groupId>com.adobe.flex.framework</groupId>
              <artifactId>framework</artifactId>
                                          <version>${flex.sdk.version}</version>
              <type>swc</type>
                                          <scope>caching</scope>
              </dependency>
              <dependency>
              <artifactId>flex-framework</artifactId>
              <type>pom</type>
              </dependency>
              <dependency>
              <artifactId>mobilecomponents</artifactId>
              <type>swc</type>
              </dependency>
              <dependency>
                                          <groupId>com.adobe.flex</groupId>
              <artifactId>fiber</artifactId>
                                          <version>4.5.0.308971</version>
              <type>swc</type>
              </dependency>
              <dependency>
              <artifactId>serializers</artifactId>
              <type>swc</type>
              </dependency>
            </dependencies>
            <pluginRepositories>
              <pluginRepository>
                                          <id>flex-mojos-repository-sites</id>
                                          <url>https://repository.sonatype.org/content/sites/flexmojos-site/</url>
              <releases>
              <enabled>true</enabled>
              </releases>
              <snapshots>
              <enabled>false</enabled>
              </snapshots>
              </pluginRepository>
              <pluginRepository>
                                          <id>flex-mojos-repository</id>
                                          <url>http://repository.sonatype.org/content/groups/flexgroup/</url>
              <releases>
              </releases>
              <snapshots>
              </snapshots>
              </pluginRepository>
              <pluginRepository>
                                          <id>yelbota-dropbox-repo</id>
                                          <url>http://dl.dropbox.com/u/36020926/maven/</url>
              <snapshots>
              </snapshots>
              <releases>
              </releases>
              </pluginRepository>
              <pluginRepository>
                                          <id>sinusgear</id>
                                          <url>http://maven.sinusgear.com/maven_repo/</url>
              <snapshots>
              </snapshots>
              <releases>
              </releases>
              </pluginRepository>
            </pluginRepositories>
            <repositories>
              <repository>
              <releases>
              </releases>
              <snapshots>
              </snapshots>
              </repository>
              <repository>
              <releases>
              </releases>
              <snapshots>
              </snapshots>
              </repository>
              <repository>
              <snapshots>
              </snapshots>
              <releases>
              </releases>
              </repository>
              <repository>
                                          <id>sinusgear</id>
              <snapshots>
              </snapshots>
              <releases>
              </releases>
              </repository>
            </repositories>
            </project>
