5 Replies Latest reply on Aug 13, 2012 6:54 AM by Peter Spier
    InDesign CS5.5 crashes with OS X Lion 10.7.4
    taylor powell Level 1
      I got the Adobe Creative Suite 5.5 Master Collection around March and had been using it without any major issues for a while on my old Macbook. Since that computer only had two gigs of ram, and was getting old, I got a the new 15" Macbook Pro with retina display. It has 16 gigs of ram. But since getting it I have been unable to get my Adobe software to work properly on it. (My old computer was running Leopard, this one has Lion, so I thought that may be the issue, but at my work they run CS5 with Lion no problem)
      Every program I have used so far has unexpectedly crashed. I am posting here because I know how to re-create the Indesign crash. Any time I try to delete a page in my document, the program quits. A warning box does come up, but it does not contain any text, and closes within a few seconds.
      I searched the forum, and found one person's solution was to save the file as an IDML. I have tried this but it did not work. I have also tried uninstalling and reinstalling everything, but that did not work either.
      Any help would be appreciated. Thanks.
      -Taylor
        • 1. Re: InDesign CS5.5 crashes with OS X Lion 10.7.4
          Also, I wasn't sure if it was wortwhile to post the problem report?
          Anyways, here it is:
          Process:         Adobe InDesign CS5.5 [18754]
          Path:            /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Adobe InDesign CS5.5
          Identifier:      com.adobe.InDesign
          Version:         7.5.0.142 (7500)
          Code Type:       X86 (Native)
          Parent Process:  launchd [110]
          Date/Time:       2012-08-12 19:35:11.375 -0400
          OS Version:      Mac OS X 10.7.4 (11E2620)
          Report Version:  9
          Sleep/Wake UUID: 1E330305-6292-4A02-9DA6-584A21AF8D19
          Interval Since Last Report:          522349 sec
          Crashes Since Last Report:           4
          Per-App Interval Since Last Report:  532 sec
          Per-App Crashes Since Last Report:   4
          Anonymous UUID:                      89B904CA-2BAD-4F00-8ADC-FBF283331A68
          Crashed Thread:  0  Dispatch queue: com.apple.main-thread
          Exception Type:  EXC_BAD_ACCESS (SIGBUS)
          Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
          VM Regions Near 0:
          --> __PAGEZERO             0000000000000000-0000000000001000 [    4K] ---/--- SM=NUL  /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Adobe InDesign CS5.5
              __TEXT                 0000000000001000-0000000000005000 [   16K] r-x/rwx SM=COW  /Applications/Adobe InDesign CS5.5/Adobe InDesign CS5.5.app/Contents/MacOS/Adobe InDesign CS5.5
          Application Specific Information:
          objc[18754]: garbage collection is OFF
          Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
          0   ???                                     0xacee2630 _XHNDL_trapback_instruction + 0
          1   ???                                     0xffffffff 0 + 4294967295
          Message was edited by: Peter Spier
          • 3. Re: InDesign CS5.5 crashes with OS X Lion 10.7.4
            Thanks. It seems like that worked. Do you know if there is a similar thing for Illustrator? (Do I need one of these for each of my programs?)
            • 4. Re: InDesign CS5.5 crashes with OS X Lion 10.7.4
              Larry G. Schneider Adobe Community Professional & MVP
              Are you using Font Explorer for font management? If so try updating the plugin. Also you should update your ID to 7.5.3 from the 7.5.0 mentioned in the crash report.
              • 5. Re: InDesign CS5.5 crashes with OS X Lion 10.7.4
                You should check in the Illustrator forum...
