0 Replies Latest reply on Aug 13, 2012 2:44 AM by EHVR
    the javascript code is not working.
    EHVR
      Hi ,
        I tried to disable a text field by using the following code. I am able to disable the field, but the field  is still allowing to enter data in disable mode also.
      The code I used is:
      var curr_state = thisItem.getProperty("state");
        var correction = getFieldByName("correction");
      if(curr_state=="New")
        if(correction)
      var correction_Style = correction.style;
         correction.disabled = true;
         correction_Style.visibility = "visible";
         correction_Style.display = "";
      else{
      correction.disabled = false;
      Is there  any mistakes in the above code?
      Need help.
      Thank you all,
      Harsha
