0 Replies Latest reply on Aug 13, 2012 6:11 AM by venkatl
    Export different tags in multiple xml
    venkatl Level 1
      I receive multiple indesign files which i need tag through stylesheet with the feature called "map styles to tag" which exports as XML, now the problem I'm facing is there are some indesign files which are having multiple stories in one files (like e.g. each story have 1 headline, 1 description and 1 body copy) so now when i export as XML i recieve multiple tags in one xml and unfortunately our backend doesn't support more than 1 tag in each XML
      So is there a way by which if i assign 3 different tags for the 3 headlines and i get a option to export it in multiple xml for the tags i select or i choose
      though i can do it manually but the quantity is huge so it'll be a too much of work and monitoring
