2 Replies Latest reply on Aug 21, 2012 12:09 PM by Kristin95762
    BorderContainer vs HorizontalList
    Kristin95762 Level 1
      Hi
      I have a borderContainer that I am loading up with an array of images from sqlite.
      As I mouse over each image, it's y value changes to indicate it's selectability.
      This all works quite well.
      The problem is that since I'm not loading these images into a data aware object, I don't have access to the information that I need.
      Ultimately I want to be able to click on the image and have an enlarged copy of it placed into a new container and display the associated
      data.
      So the question is how to link the data to the image? What is the method I would use here?
      Unless I can get a list control to perform the way I want it to...
      Kristin
      private function result(event:SQLEvent):void
                                              var data:Array = selectStmt.getResult().data;
                                              for (var i:int = 0; i < data.length; i++)
                                                        var card:Loader = new Loader();
                                                        imageUrl = "assets/" + data[i].image;
      cardImage = new UIComponent();
                                                        card.load(new URLRequest(imageUrl));
                                                        cardImage.addChild(card);
                                                        bc1.addElement(cardImage);
                                                        cardImage.scaleX = .5;
                                                        cardImage.scaleY = .5;
                                                        cardImage.x = 25*i;
                                                        cardImage.y = 5;
                                                        cardImage.addEventListener(MouseEvent.ROLL_OVER, onRollOver);
                                                        cardImage.addEventListener(MouseEvent.ROLL_OUT, onRollOut);
                                    private function onRollOver(e:MouseEvent):void
      var hoveredImage:Object = e.currentTarget;
                                              hoveredImage.y = -15;
                                              cardImage.removeEventListener(MouseEvent.ROLL_OUT, onRollOver);
                                    private function onRollOut(e:MouseEvent):void
                                              hoveredImage.y = 5;
                                              cardImage.removeEventListener(MouseEvent.ROLL_OVER, onRollOut);
