6 Replies Latest reply on Aug 14, 2012 4:00 PM by bt4design
    Indesign CS5.5 Relink Script needs help
    bt4design
      Hi, I'm trying to relink images in an InDesign CS5.5 file to a different server using a script. This is what I have so far, but when I run the script I get errors and can't relink because "Either the file does not exist, you do not have permission, or the file may be in use by another application". Does anyone know how to make this script work? I'm fairly new to scripting.
      Here is the script I have:
      tell application "Adobe InDesign CS5.5"
                tell document 1
                          set linkList to links
                          set errInfo to "" -- We'll display error if we can't relink an item
                          repeat with x in linkList
                                    if (x's status) is not normal then -- I usually check for any link that has an error
        -- This should only return an AppleScript path with ":" separators
                                              set linkPath to (x's file path) as string
                                              if "Volumes/Calendars_2013 FPO" is in linkPath then
                                                        set AppleScript's text item delimiters to "Volumes/Calendars_2013 FPO"
                                                        set linkPath to (linkPath's text items) -- Create a list of text items
                                                        set AppleScript's text item delimiters to "Volumes/Calendars_2013"
                                                        set linkPath to (linkPath as string) -- Concatenate with new path
                                                        set AppleScript's text item delimiters to "" -- Reset TIDs
                                                        try
        -- Need to make our string (path) into an alias path
        relink x to alias linkPath
        try
        update x -- This can be helpful
        end try
                                                        on error err
        -- We'll store link name if error occurs
        set errInfo to (errInfo & return & x's name)
                                                        end try
                                              end if
                                    end if
                          end repeat
        -- If an error occurs while trying to relink, we'll display it
                          if (count errInfo) > 0 then display dialog ("Can't relink:" & errInfo)
                end tell
      end tell
      --Hector
        • 1. Re: Indesign CS5.5 Relink Script needs help
          -hans- Level 4
          'Volumes/...' is a posix path. file path on a mac returns hfs path. try hfs: "Calendars_2013 FPO:" instead of posix: "Volumes/Calendars_2013 FPO"
          • 2. Re: Indesign CS5.5 Relink Script needs help
            bt4design Level 1
            I just tried adding collens to the end of the folder path. For some reason the script skipped the relink line. Below is the code with your update. I'm thinking its not finding the images because the script needs to make a list of all the images and choose the one that matches the missing image.
                      tell document 1
                                                    if "Calendars_2013 FPO:" is in linkPath then
                                                              set AppleScript's text item delimiters to "Calendars_2013 FPO:"
                                                              set AppleScript's text item delimiters to "Calendars_2013:"
                                                              try
        try
        end try
                                                              on error err
                                                              end try
                                                    end if
                                          end if
                                end repeat
                      end tell
            end tell
            --Thanks for you help
            • 3. Re: Indesign CS5.5 Relink Script needs help
              -hans- Level 4
              just checked the script and it works properly.
              this line ' if (x's status) is not normal then' stopps any relinking if the status of the link is normal.
              perhaps here's the reason / missunderstanding for you to say the script skips ....
              so what do you want to do¿
              relink the links whose status is equal to normal? then change the line to 'if (x's status) is  normal then' ... ;-)
              • 4. Re: Indesign CS5.5 Relink Script needs help
                bt4design Level 1
                Hello,
                I just tried the script I last posted. This is the result I receive when I run the script:
                get status of link id 75673 of image id 74442 of rectangle id 74441 of spread id 45573 of document id 25
                  --> link missing
                          get file path of link id 75673 of image id 74442 of rectangle id 74441 of spread id 45573 of document id 25
                                    --> "/Volumes/Calendars_2013 FPO/2013_Dog_Breeds/2013_A_B/9764-2_BichonPups_SQ/9764-2_imagefolder_SQ2013/9764-2_01a_SQ 2013.jpg"
                end tell
                --What I want the script to do is for the link that is missing to be relinked to the new location 'Calendar_2013'. I'm not sure why it's skipping this step in the script:
                try
        try
                --thanks again
                • 5. Re: Indesign CS5.5 Relink Script needs help
                  -hans- Level 4
                  hi,
                  whatever ... the dictionary says ...
                                      --> "/Volumes/Calendars_2013 FPO/2013_Dog_Breeds/2013_A_B/9764-2_BichonPups_SQ/9764-2_imagefolder_ SQ2013/9764-2_01a_SQ2013.jpg"
                  this is no macPath.
                  so let's try the text item delimiters from you first post and:
                    relink x to posix file linkPath
                  Hope it'll work
