1 Reply Latest reply on Feb 17, 2008 9:40 AM by Gregory Lafrance
    Navigation Problem
    Nutan.lade
      I developed an application and in that home page i had created some viewstack and named it as portals and some components.using link buttons and viewstack i am able to navigate between components from home page.But I am facing a problem that when i am trying to navigate from one of the components it is now recognizing.
      For example I placed Register linkbutton in homeview component.so when I click these button it should navigate to that register component from homeview component.How can i do this.I placed this code in homeview component but it didnt worked.
      click="portals.Selectedchild=register";
      please suggest me some other method or any corrections.
        • 1. Re: Navigation Problem
          Gregory Lafrance Level 6
          I don't know if this will help, but here is a ViewStack sample app I created:
          Here is a sample app I created to show using ViewStack for an entire website:
          ------------------------- ViewStack1.mxml ---------------------
          <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns:comp="components.*"
          layout="vertical" width="100%" height="100%" >
          <comp:TopBar />
          <mx:HBox width="100%" height="100%">
          <comp:LeftBar />
          <mx:VBox width="100%" height="100%">
          <mx:ViewStack id="myViewStack" borderStyle="none" width="100%" height="100%">
          <mx:VBox id="home" width="100%">
          <comp:MainIntroText />
          <mx:HRule width="50%" height="3" strokeColor="0xCC3333"/>
          <comp:MainSecondaryText />
          <comp:MainFinalText />
          </mx:VBox>
          <mx:VBox id="about" width="100%">
          <comp:About />
          </mx:VBox>
          <mx:VBox id="contact" width="100%">
          <comp:Contact />
          </mx:VBox>
          </mx:ViewStack>
          </mx:VBox>
          </mx:HBox>
          </mx:Application>
          ------------------------------- About.mxml -----------------------
          <mx:HBox xmlns:mx=" http://www.adobe.com/2006/mxml" width="100%">
          <mx:VBox width="65%">
          <mx:Text fontSize="14" width="100%" text="This page tells you about us." />
          </mx:VBox>
          </mx:HBox>
          ----------------------------------- Contact.mxml ---------------------------
          <mx:Text fontSize="14" width="100%" text="This page tells you how to contact us." />
          </mx:VBox>
          </mx:HBox>
          ------------------- LeftBar.mxml -------------------------
          <mx:VBox xmlns:mx=" http://www.adobe.com/2006/mxml" width="200" height="100%">
          <mx:LinkButton label="Adobe Labs - Flex"
          click="navigateToURL(new URLRequest(' http://labs.adobe.com/technologies/flex'), '_blank');"/>
          <mx:Spacer height="20"/>
          <mx:Label fontSize="16" text="Flex Blogs"/>
          <mx:LinkBar direction="vertical" width="90%" itemClick="navigateToURL(new URLRequest(event.item.data), '_blank');">
          <mx:Object label="Adobe Flex Team Blog" data=" http://weblogs.macromedia.com/flexteam/"/>
          <mx:Object label="Flex Blog Aggregator" data=" http://www.allyourflexarebelongtous.com/"/>
          <mx:Object label="Adobe Flex Blog Aggregator" data=" http://weblogs.macromedia.com/mxna/index.cfm?query=byCategory&#38;categoryId=5&#38;categor yName=Flex"/>
          </mx:LinkBar>
          <mx:Label fontSize="16" text="Example Flex Apps"/>
          <mx:LinkBar direction="vertical" id="addlRscList" width="90%" itemClick="navigateToURL(new URLRequest(event.item.data), '_blank');">
          <mx:Object label="Adobe Flex Store" data=" http://www.adobe.com/devnet/flex/samples/flex_store_v2/"/>
          <mx:Object label="Adobe Dashboard Example" data=" http://examples.adobe.com/flex2/inproduct/sdk/dashboard/dashboard.html"/>
          <mx:Object label="Buzzword Word Processor" data=" http://preview.getbuzzword.com/?s=true"/>
          <mx:Object label="Adobe Style Explorer" data=" http://examples.adobe.com/flex2/consulting/styleexplorer/Flex2StyleExplorer.html"/>
          <mx:Object label="Adobe Component Explorer" data=" http://examples.adobe.com/flex2/inproduct/sdk/explorer/explorer.html"/>
          </mx:LinkBar>
          </mx:VBox>
          ----------------------- MainFinalText.mxml ----------------------------
          <mx:VBox xmlns:mx=" http://www.adobe.com/2006/mxml" width="100%">
          <mx:Text width="100%" fontSize="12"
          text="Here is the final text I want to show you." />
          </mx:VBox>
          --------------------------- MainIntroText.mxml -------------------------------
          text="Here is the main text I want to show you." />
          </mx:VBox>
          ----------------------- MainSecondaryText.mxml --------------------------------
          text="Here is the secondary text I want to show you." />
          </mx:VBox>
          --------------- TopBar.mxml --------------------------------
          <mx:Script>
          <![CDATA[
          private function goToViews(view:String):void {
          if(view == "home"){
          this.parentApplication.myViewStack.selectedChild=this.parentApplication.home;
          if(view == "about"){
          this.parentApplication.myViewStack.selectedChild=this.parentApplication.about;
          if(view == "contact"){
          this.parentApplication.myViewStack.selectedChild=this.parentApplication.contact;
          </mx:Script>
          <mx:LinkButton label="MySnazzyLogo" fontSize="20" click="goToViews('home');" />
          <mx:VBox width="100%">
          <mx:HBox width="100%">
          <mx:Spacer width="100%" />
          <mx:LinkBar fontSize="14" itemClick="goToViews(String(event.item.data));">
          <mx:Array>
          <mx:Object label="About Us" data="about"/>
          <mx:Object label="Contact Us" data="contact"/>
          </mx:Array>
          </mx:LinkBar>
          </mx:HBox>
          <mx:Spacer width="150" />
          <mx:Label fontSize="25" text="Here is Some Additional Text" />
          </mx:HBox>
          </mx:VBox>
          </mx:HBox>
