2 Replies Latest reply on Aug 14, 2012 1:46 PM by Mathias17
    Setting a Drop Shadow to Overprint
    Mathias17 Level 3
      Rather than drop shadows knock fuzzy holes in underlying separations, is there a way to set a Drop Shadoo to always overprint?
        • 1. Re: Setting a Drop Shadow to Overprint
          MikeGondek Adobe Community Professional & MVP
          Illustrator Drop Shadows are set to multiply by default.
          If you are talking about drop shadows from Photoshop placed images, you need to make 2 photoshop files to achieve this.
          1. Photoshop file without drop shadow on top
          2. Photoshop file with drop shadow set to multiply in Illustrator underneath the other image
          To get the images to register, you just need to copy 1 oplace image and paste in front, then use the links panel to relink to the other image.
          • 2. Re: Setting a Drop Shadow to Overprint
            Mathias17 Level 3
            What now? No, just typical Illustrator drop shadows, live effects. But you comment about Multiply Mode . . .
            I checked into that. I had turned it off so I could eliminate hard-to-predict print problems resulting from using fancy effects.
            Turns out, Multiply Mode makes the shad overprint. The proof:
            Overprint off:
            Overprint on. Drop Shadow blend mode: Normal.
            Overprint on. Drop Shadow blend mode: Multiply.
            Nice! Thanks, Mike.
