7 Replies Latest reply on Apr 10, 2013 2:08 AM by wu.shan
    Multiple smartimage widgets in a component dialog
    joel_triemstra Level 1
      Is there a way to have multiple smartimage widgets in a single dialog? Specifically I'm struggling with the requestSuffix parameter. Most of the other ones I can adapt to get the second widget to save its info to a different location from the first, but I can't see how to do that with requestSuffix. If the values are the same for both widgets, then once an image is selected, I see the same image in both tabs of the dialog. If I change it to something like /image2.img.png, it's no longer hitting the component as the resource. If I change it to .image2.img.png, the script handling this selector appears to break. I might be able to change that script, but that doesn't seem like it'll be a very flexible approach.
      Any other options? I'm in CQ 5.4 if that matters.
        • 1. Re: Multiple smartimage widgets in a component dialog
          Yogesh Upadhyay Level 4
          Joel,
          Good question. Using multiple image in a dialog is kind of complicated but can be done. But I am not sure how to use them in multifield (Love to here if some has done that using OOTB xtype). Here is example of using mutiple image in dialog
          <items jcr:primaryType="cq:WidgetCollection">
                  <tab1
                      jcr:primaryType="cq:Widget"
                      title="Settings"
                      xtype="panel">
                          <resType1
                              ignoreData="{Boolean}true"
                              name="./image1/sling:resourceType"
                              value="foundation/components/image"
                              xtype="hidden"/>
                          <resType2
                              name="./image2/sling:resourceType"
                              xtype="hidden"/>
          </tab1>
          <tab2
                      cropParameter="./image1/imageCrop"
                      ddGroups="[media]"
                      fileNameParameter="./image1/fileName"
                      fileReferenceParameter="./image1/fileReference"
                      mapParameter="./image1/imageMap"
                      name="./image1/file"
                      requestSuffix="/image1.img.png"
                      rotateParameter="./image1/imageRotate"
                      sizeLimit="100"
                      title="Frame Image"
                      xtype="html5smartimage"/>
                  <tab3
                      cropParameter="./image2/imageCrop"
                      ddGroups="[media]"
                      fileNameParameter="./image2/fileName"
                      fileReferenceParameter="./image2/fileReference"
                      mapParameter="./image2/imageMap"
                      name="./image2/file"
                      requestSuffix="/image2.img.png"
                      rotateParameter="./image2/imageRotate"
                      sizeLimit="100"
                      title="Lightbox Image"
          And then edit config drop target something like this,
          <cq:dropTargets jcr:primaryType="nt:unstructured">
                  <image
                      jcr:primaryType="cq:DropTargetConfig"
                      accept="[image/.*]"
                      groups="[media]"
                      propertyName="./image1/fileReference">
                      <parameters
                          sling:resourceType="foundation/components/image"
                          imgAlignment="left">
                          <image2
                              imageCrop=""
                              imageMap=""
                              imageRotate=""/>
                          <image1
                              imageCrop=""
                              imageMap=""
                              imageRotate=""/>
                      </parameters>
                  </image>
              </cq:dropTargets>
          Yogesh
          • 2. Re: Multiple smartimage widgets in a component dialog
            Wow, thanks, that's a lot to digest. I tried implementing this structure for just one image to make sure I had that right. I can successfully add an image to the widget and save it, but when I try to view it again, I get a 404 on image1.img.png. I've got a lot in this to experiment with, but if there's something you can think of that would cause that, it'd be great to hear.
            Also, I don't think I have the html5smartimage available, since I'm in 5.4, if that matters.
            • 3. Re: Multiple smartimage widgets in a component dialog
              -- Where are you trying to view it ? By opening your dialog again or in your script ? You have to make sure that you add those hidden type for this to work.
              -- That should not matter. You can use available xtype for CQ5.4
              Can you send your dialog.xml and _edit_config.xml ?
              Yogesh
              • 4. Re: Multiple smartimage widgets in a component dialog
                I was trying by opening the dialog again. I did end up finding that I had the ignoreData value wrong in the hidden type. When I updated that, I got the dialog to open again successfully, but I see a JS error that says "selection is null" in
                widgets.js, with the line "context.doc.execCmd("useCSS", true);" The dialog appears to function, though, so it may not be a high priority. This is my XML
                <jcr:root xmlns:cq="http://www.day.com/jcr/cq/1.0" xmlns:jcr="http://www.jcp.org/jcr/1.0" xmlns:nt="http://www.jcp.org/jcr/nt/1.0"
                    jcr:primaryType="cq:Dialog"
                    title="Offer"
                    xtype="dialog">
                    <items jcr:primaryType="cq:TabPanel">
                            <tab1
                                jcr:primaryType="cq:Panel"
                                title="Copy Snippets">
                                    <offerCode
                                        fieldLabel="Offer Code: "
                                        name="./offerCode"
                                        xtype="textfield"/>
                                    <dropdownCopy
                                        fieldLabel="Copy in drop-down list: "
                                        name="./dropdownCopy"
                                        xtype="textfield"/>
                                    <listPageCopy
                                        hideLabel="{Boolean}true"
                                        name="./listPageCopy"
                                        xtype="richtext">
                                        <rtePlugins jcr:primaryType="nt:unstructured">
                                            <misctools
                                                features="*"/>
                                        </rtePlugins>
                                    </listPageCopy>
                                    <congratulationsCopy
                                        fieldLabel="Congratulations Copy"
                                        name="./congratulationsCopy"
                                        xtype="textfield"/>
                                </items>
                            </tab1>
                            <image1
                                ddGroups="[media]"
                                title="Image"
                                uploadUrl="/tmp/upload/*"
                                xtype="smartimage"/>
                            <hidden
                                title="Settings"
                                xtype="panel">
                                    <resType1
                                        xtype="hidden"/>
                                </items>
                            </hidden>
                        </items>
                    </items>
                </jcr:root>
                <jcr:root xmlns:sling="http://sling.apache.org/jcr/sling/1.0" xmlns:cq="http://www.day.com/jcr/cq/1.0" xmlns:jcr="http://www.jcp.org/jcr/1.0" xmlns:nt="http://www.jcp.org/jcr/nt/1.0"
                    jcr:primaryType="cq:EditConfig">
                        <image
                            accept="[image/.*]"
                            groups="[media]"
                            <parameters
                                <image1
                                    imageCrop=""
                                    imageMap=""
                                    imageRotate=""/>
                            </parameters>
                        </image>
                    </cq:dropTargets>
                </jcr:root>
                • 5. Re: Multiple smartimage widgets in a component dialog
                  Is this complete dialog.xml ? From your dialog.xml it does not looks like you are using multiple images. If you are using only one image in your dialog.xml then you do not have to do any additonal configuration. See example of textImage component in CQ to set up dialog with just one image.
                  Yogesh
                  • 6. Re: Multiple smartimage widgets in a component dialog
                    At the time I posted it, yes, it was the complete XML. Since this configuration was a little different than the image component that I was originally copying from, I wanted to make sure I could get it working with just 1 image before I set all the properties for the 2nd image.
                    • 7. Re: Multiple smartimage widgets in a component dialog
                      wu.shan Level 1
                      it does't work under Version 5.5.0 20120220 Service Pack 2. Has anyone idee?
                      thanks,
                      shan
