1. Re: Robohelp 10 Upgrade loses Resource Links
Peter Grainge Aug 16, 2012 5:08 AM (in response to mcallit82)Try copying the file from the Rh9 version to Rh10 and then reopening the project. Just a wild guess.
2. Re: Robohelp 10 Upgrade loses Resource Links
eeddings Aug 16, 2012 8:17 AM (in response to Peter Grainge)Same issue here, too. That was my first reaction, Peter, and unfortunately it doesn't work. I did eventually find a solution. Sorry for the wall of text that follows, but documented is exactly what I found and fixed.
The *only* changes I can see in the rhsharedresource.apj from RH9 to RH10 are as follows (may be others, but I'm not seeing them):
RH9
<rhpml majorversion="4" minorversion="0">
RH10
<rhpml majorversion="5" minorversion="0">
RH9 image links
<type>3</type>
RH10 image links
<type>6</type>
RH9 snippet links
<type>10</type>
RH10 snippet links
<type>11</type>
Below are my findings.
If I upgrade a RH9 project to RH10, the rhsharedresource.apj is completely blank after the project upgrade, and it looks exactly like this.
<links/>
<syncoption>
<mode>0</mode>
</syncoption>
</rhpml>
if I replace the newly upgraded rhsharedresource.apj with the old version from RH9 (without changing a thing in it) then open the project, the links are still lost. The old rhsharedresource.apj looks something like this (only two links are depicted below -- a snippet and an image):
<links>
<link>
<shr_path>C:\TechComm\rsrcmgr\SPIRIT\rsrcs\ctrl_clmn_exception_reason_lvl4.hts</shr_path>
<prj_path>ctrl_clmn_exception_reason_lvl4.hts</prj_path>
<type>10</type>
<checkSum>E696925804FFF20E9DC5C3302D265262</checkSum>
<remoteModtime>1343660808</remoteModtime>
</link>
<link>
<shr_path>C:\TechComm\rsrcmgr\SPIRIT\rsrcs\image\btn_tbar_assigned_caseload.jpg</shr_path >
<prj_path>image\btn_tbar_assigned_caseload.jpg</prj_path>
<type>3</type>
<checkSum>BC8765991C25A4C0335B4F98FBE9764B</checkSum>
<remoteModtime>1324573797</remoteModtime>
</link>
</links>
<syncoption>
<mode>0</mode>
</syncoption>
</rhpml>
If in RH10 I create links to an image and a snippet from my Resource Manager (and close the project to save the rhsharedresource.apj), the rhsharedresource.apj RH9 (above) that overwrote the RH10 version is completely cleared of all old <link>s and the new <link>s are added -- note also that the <rhpml majorversion="4" minorversion="0"> was not changed to <rhpml majorversion="5" minorversion="0">:
<links>
<link>
<shr_path>C:\TechComm\rsrcmgr\SPIRIT\rsrcs\image\add_abuse.jpg</shr_path>
<prj_path>add_abuse.jpg</prj_path>
<type>6</type>
<checkSum>D475EDA6B33A370E0EE2F2BFD43AB7CB</checkSum>
<remoteModtime>1340649613</remoteModtime>
</link>
<link>
<shr_path>C:\TechComm\rsrcmgr\SPIRIT\rsrcs\busrule_latepickup_general_lvl1.hts</shr_path>
<prj_path>busrule_latepickup_general_lvl1.hts</prj_path>
<type>11</type>
<checkSum>D07E1BDE7672065A2DF183AD9A4DD894</checkSum>
<remoteModtime>1340649391</remoteModtime>
</link>
</links>
<syncoption>
<mode>0</mode>
</syncoption>
</rhpml>
If I then copy the other 1000+ <link>s from my old RH9 rhsharedresoruce.apj and paste them manually into the newly-created rhsharedresource.apj (above), without changing the <type>, close the project and reopen, the links are still all gone but the rhsharedresource.apj did not remove the <link>s I pasted into it. Looks like this:
<links>
<link>
<type>6</type>
</link>
<link>
<type>11</type>
</link>
****Pasted in <link>s begin here****
<link>
<shr_path>C:\TechComm\rsrcmgr\SPIRIT\rsrcs\msg_e0006_mnuopt_lvl3.hts</shr_path>
<prj_path>msg_e0006_mnuopt_lvl3.hts</prj_path>
<type>10</type>
<checkSum>CE15BA171163E6646CA3A17582B1139B</checkSum>
<remoteModtime>1343660870</remoteModtime>
</link>
<link>
<shr_path>C:\TechComm\rsrcmgr\SPIRIT\rsrcs\image\btn_browse.jpg</shr_path>
<prj_path>image\btn_browse.jpg</prj_path>
<type>3</type>
<checkSum>D7A5810E88DAFD620A9EC575FEFF62C7</checkSum>
<remoteModtime>1340800474</remoteModtime>
</link>
****The rest has been removed to keep this thread shorter****
If I then change all <type>3</type> to <type>6</type> and all <type>10</type> to <type>11</type> (the ones I pasted in from the old RH9 rhsharedresource.apj file to match the new RH10 <type>s), close the project and reopen:
<links>
<link>
<type>6</type>
</link>
<link>
<type>11</type>
</link>
<link>
<type>11</type>
</link>
<link>
<type>6</type>
</link>
THE LINKS ARE RESTORED! HALLELUJAH!
There may be an easier way to get to this result, but I've spent enough time on it this morning. Hope this helps.
EDIT:
I should also add that I went back into the rhsharedresource.apj and changed the
<rhpml majorversion="4" minorversion="0"> to <rhpml majorversion="5" minorversion="0">, closed/reopened the project and nothing was broken (that I could see).
3. Re: Robohelp 10 Upgrade loses Resource Links
eeddings Aug 16, 2012 8:33 AM (in response to eeddings)Okay, further testing reveals that if I change the rhsharedresource.apj <type>s before upgrade, all is fixed instantly after the upgrade.
Before upgrading, in the rhsharedresource.apj, change all <type>3</type> to <type>6</type> and all <type>10</type> to <type>11</type>, then upgrade the project.
Hope this helps.
4. Re: Robohelp 10 Upgrade loses Resource Links
mcallit82 Aug 16, 2012 1:39 PM (in response to eeddings)Thanks for figuring that out. It'll save a lot of time.
