3 Replies Latest reply on Aug 17, 2012 10:15 AM by Flex harUI
    Flex 3 Item renderer in List dissapear and shifted place
    M.Kang
      I successfully added ItemRenderer in my List but whenever I scroll down to the bottom and scroll up again. The ItemRenderer in the List would be either gone or shifted places.
      I have search up on possible solution but they doesn't seen like working. I tried to put dataChange=”validateNow()” in the ItemRenderer but it doesn't work. I read something about useVirtualLayout="false" but it seen like my List doesn't have useVirtualLayout ?
      <mx:List
      id="rowsList2" width="{VBoxCall.width}" height="{ scheduleViewerHeight }"
      rowHeight="{ scheduleViewer.rowHeight }"
      verticalScrollPolicy="off" verticalAlign="middle"
      horizontalScrollPolicy="off"
      alternatingItemColors="[0xEEEEEE, 0xDFDFDF]" itemRenderer="RendererState">
      <!-- Example to showcase Item renderer -->
      <mx:dataProvider>
      <mx:Object label="Mr Swabby"
      data="Juneau"
      webPage="http://www.state.ak.us/"/>
      <mx:Object label="Mrs Harrington"
      data="Montgomery"
      webPage="http://www.alabama.gov/" />
      </mx:dataProvider>
      </mx:List>
      Before (picture) http://i.stack.imgur.com/VxoeP.gif
      After (picture) http://i.stack.imgur.com/3qHO9.gif
      Any Ideas ?
      Regards, Mike
        • 1. Re: Flex 3 Item renderer in List dissapear and shifted place
          Flex harUI Adobe Employee
          UseVirtualLayout is for Spark List.  You issue sounds like a recycling problem.  See the item renderer posts on my blog.
          Alex Harui
          Flex SDK Team
          Adobe Systems, Inc.
          http://blogs.adobe.com/aharui
          • 2. Re: Flex 3 Item renderer in List dissapear and shifted place
            M.Kang Level 1
            Hi Alex,
            I've read your blog but I still could find the solution.
            I tried to override the set data but it is not working. Whenever I scroll to the bottom and move up again, all the buttons are gone.
            Please advise me on this.
            Regards,
            Mike
            <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml">
                      <mx:Script>
                                <![CDATA[
                                          // Import Event and URLRequest classes.
                                          import flash.events.Event;
                                          import flash.net.URLRequest;
                                          override public function set data(value:Object):void{
                                                    if(value != null)
                                                    super.data = value;
                                                    if(data.label == null)
                                                              Button.label="";
                                                    else
                                                              if(data.label == null || data.label=="")
        Button.label = "";
                                                              else
        Button.label = data.label;
                                                    else
                                                              myVBox.removeChild(Button);
                      </mx:Script>
                      <mx:VBox id="myVBox">
                                <mx:Button id="Button" width="90">
                                </mx:Button>
                      </mx:VBox>
            </mx:VBox>
            • 3. Re: Flex 3 Item renderer in List dissapear and shifted place
              You have code that removes Button, but I don’t see any code to re-add it.  Once the Button is removed and that renderer is recycled, it will not get re-added.
