1 Reply Latest reply on Aug 16, 2012 7:08 AM by SAFEHARBOR11
    Premiere problem exporting video
    bjacky2004
      When I export widescreen video in avi, widescreen preset, when I open the file with vlc it opens it like it would been in 4:3 format, not widescreen. Can you help me about it?If I export it in mpeg2 it looks fine.  Have a nice day!
        • 1. Re: Premiere problem exporting video
          SAFEHARBOR11 Most Valuable Participant
          Widescreen SD is an "anamorphic" format. This means that the PAR (pixel aspect ratio) is different to give the appearance of widescreen, even though the frame dimensions are the same. NTSC DV uses 720x480 for both 4:3 and 16:9, with PARs of 0.9 and 1.2 respectively. The rectangular pixels of widescreen DV with 1.2 PAR provide the widescreen image look.
          Some software players do not look at the PAR and assume a 1.0 PAR (square pixels) and that is why your video is displayed as 4:3.
          If creating a video for online display, you may have to correct using pixels, which means export at 854x480 using a 1.0 PAR and then it will always look like 16:9 when viewed. For PAL, I believe 1024x576 is correct for 1.0 PAR, not certain though.
          Jeff Pulera
          Safe Harbor Computers
