4 Replies Latest reply on Aug 20, 2012 9:23 PM by sridharib
    Adobe CQ integration with Liferay
    sridharib
      Hi
      I am trying to integrate adobe CQ 5.5 with Liferay using CMIS. I followed this link http://dev.day.com/docs/en/crx/current/deploying/cmis.html to enable CMIS in Adobe CQ but i got this error:
      No resource found
      Cannot serve request to /cmis/repository in /libs/sling/servlet/errorhandler/404.jsp
      Request Progress:
      0 (2012-08-09 11:03:33) TIMER_START{Request Processing}
      0 (2012-08-09 11:03:33) COMMENT timer_end format is {<elapsed msec>,<timer name>} <optional message>
      0 (2012-08-09 11:03:33) LOG Method=GET, PathInfo=/cmis/repository
      0 (2012-08-09 11:03:33) TIMER_START{ResourceResolution}
      1 (2012-08-09 11:03:33) TIMER_END{1,ResourceResolution} URI=/cmis/repository resolves to Resource=NonExistingResource, path=/cmis/repository
      1 (2012-08-09 11:03:33) LOG Resource Path Info: SlingRequestPathInfo: path='/cmis/repository', selectorString='null', extension='null', suffix='null'
      1 (2012-08-09 11:03:33) TIMER_START{ServletResolution}
      1 (2012-08-09 11:03:33) TIMER_START{resolveServlet(NonExistingResource, path=/cmis/repository)}
      3 (2012-08-09 11:03:33) LOG {0}: no servlet found
      3 (2012-08-09 11:03:33) TIMER_END{2,resolveServlet(NonExistingResource, path=/cmis/repository)} Using servlet org.apache.sling.servlets.get.DefaultGetServlet
      3 (2012-08-09 11:03:33) TIMER_END{2,ServletResolution} URI=/cmis/repository handled by Servlet=org.apache.sling.servlets.get.DefaultGetServlet
      3 (2012-08-09 11:03:33) LOG Applying Requestfilters
      3 (2012-08-09 11:03:33) LOG Calling filter: org.apache.sling.bgservlets.impl.BackgroundServletStarterFilter
      3 (2012-08-09 11:03:33) LOG Calling filter: org.apache.sling.rewriter.impl.RewriterFilter
      3 (2012-08-09 11:03:33) LOG Calling filter: com.day.cq.wcm.core.impl.WCMRequestFilter
      3 (2012-08-09 11:03:33) LOG Calling filter: org.apache.sling.i18n.impl.I18NFilter
      3 (2012-08-09 11:03:33) LOG Calling filter: com.day.cq.theme.impl.ThemeResolverFilter
      3 (2012-08-09 11:03:33) LOG Calling filter: com.day.cq.wcm.foundation.forms.impl.FormsHandlingServlet
      3 (2012-08-09 11:03:33) LOG Calling filter: org.apache.sling.engine.impl.debug.RequestProgressTrackerLogFilter
      3 (2012-08-09 11:03:33) LOG Calling filter: com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter
      3 (2012-08-09 11:03:33) LOG RedirectFilter did not redirect (request extension does not match)
      3 (2012-08-09 11:03:33) LOG Calling filter: com.day.cq.wcm.core.impl.warp.TimeWarpFilter
      3 (2012-08-09 11:03:33) LOG Applying Componentfilters
      3 (2012-08-09 11:03:33) LOG Calling filter: com.day.cq.wcm.core.impl.WCMComponentFilter
      3 (2012-08-09 11:03:33) LOG Calling filter: com.day.cq.wcm.core.impl.WCMDebugFilter
      3 (2012-08-09 11:03:33) TIMER_START{org.apache.sling.servlets.get.DefaultGetServlet#0}
      3 (2012-08-09 11:03:33) TIMER_END{0,org.apache.sling.servlets.get.DefaultGetServlet#0}
      3 (2012-08-09 11:03:33) LOG Applying Error filters
      3 (2012-08-09 11:03:33) TIMER_START{handleError:status=404}
      3 (2012-08-09 11:03:33) TIMER_END{0,handleError:status=404} Using handler /libs/sling/servlet/errorhandler/404.jsp
      4 (2012-08-09 11:03:33) LOG Found processor for post processing ProcessorConfiguration: {contentTypes=[text/html],order=-1, active=true, valid=true, processErrorResponse=true, pipeline=(generator=Config(type=htmlparser, config={}), transformers=(Config(type=linkchecker, config={}), Config(type=mobile, config=org.apache.sling.jcr.resource.JcrPropertyMap@1170538), Config(type=mobiledebug, config=org.apache.sling.jcr.resource.JcrPropertyMap@57d154), Config(type=contentsync, config=org.apache.sling.jcr.resource.JcrPropertyMap@16ff991), serializer=Config(type=htmlwriter, config={}))}
      4 (2012-08-09 11:03:33) TIMER_END{4,Request Processing} Dumping SlingRequestProgressTracker Entries
      After that i downloaded CRX v 2.2 and try the same thing. I was able to connect to repository successfully but not able to display any folders. When i try to create a folder i got this error:
      Exception in thread "main" org.apache.chemistry.opencmis.commons.exceptions.CmisInvalidArgumentException: Property cmis:objectTypeId must be set!
                at org.apache.chemistry.opencmis.client.bindings.spi.atompub.ObjectServiceImpl.checkCreatePr operties(ObjectServiceImpl.java:648)
                at org.apache.chemistry.opencmis.client.bindings.spi.atompub.ObjectServiceImpl.createFolder( ObjectServiceImpl.java:135)
                at org.apache.chemistry.opencmis.client.runtime.SessionImpl.createFolder(SessionImpl.java:76 9)
                at org.apache.chemistry.opencmis.client.runtime.FolderImpl.createFolder(FolderImpl.java:129)
                at org.apache.chemistry.opencmis.client.runtime.FolderImpl.createFolder(FolderImpl.java:453)
                at CMISAtomTest.main(CMISAtomTest.java:42)
      Please Help
