2 Replies Latest reply on Aug 17, 2012 12:34 AM by thomas_th21
    Convert XML to string
    thomas_th21 Level 1
      Hello,
      I have the following situation:
      I make an application that stores data in a valid XML file.
      The storage of the data with a File.IO operation works well but when I trie to send the file over the internet using a string, it gives me an objectname.
      So I have this code for sending the data over the internet :
        data = myCertGen.writeXML(myData) --Get my data from a XML obejct
        --the data that I want to save.
        tData = ["name":"pcdata.ts","datos":data]
        --call PHP script.
        gNetID = postNetText("http://dev-site.com/telesiminar/save.php",tData)
      So I get my data from the class who makes the XML. This is a XML object.
      Then I send the file over the internet to a php file.
      Now in my data I only get <FlashObject d59cd70>
      So I know this is a object. Now is my question how do I convert this object back to a string wich I can send ?
        • 1. Re: Convert XML to string
          Sean_Wilson Adobe Community Professional
          I guess the 'data' you refer to is the "datos" of your property list. Perhaps you can use the toString() method.
            data = myCertGen.toString(data)
            put data
          This might work, but it isn't clear from what you posted what sort of an object myCertGen points to.
          • 2. Re: Convert XML to string
            thomas_th21 Level 1
            mycergen is an own created class with function inside it.
            the point is that it returns an XML object, so data is an XML object.
            But I solved the problem by using a string instead of an object.
            Thanks anyway for the response
