1 Reply Latest reply on Jul 24, 2013 6:49 AM by thomas wornall
    Quality Setting for TIFF/JPG using SaveAs
    SD2k12
      I'm trying to export a jpg or tiff as a "preview" image for a single pdf page. However, they look terrible - I am accessing the javascript object through C# and calling "SaveAs", but I can't find any parameters or methods to set the quality of the image. Can anyone help?
      Edit: Using Acro 9/X.
        • 1. Re: Quality Setting for TIFF/JPG using SaveAs
          thomas wornall
          what i ended up doing was using c# to open a pdf select the first page and copying it to clipboard then pulling the image back out of the clipboard, resizing and saving...
          public static void copyPdfCoverToClipboard(string filePath)
                      arc.AcroAVDoc afile = new arc.AcroAVDoc();
                      bool returned = afile.Open(filePath,"");
                      if (returned == true) {
                          //Console.WriteLine("opened file");
                      arc.AcroPDDoc temp = afile.GetPDDoc();
                      arc.AcroPDPage apage = temp.AcquirePage(0);
                      arc.AcroPoint size = apage.GetSize();
                      arc.AcroRect rect = new arc.AcroRect();
                      rect.Top = 0;
                      rect.Left = 0;
                      rect.right = size.x;
                      rect.bottom = size.y;
                      bool returned2 = apage.CopyToClipboard(rect, 0, 0, 100);
                      if (returned2 == true) {
                          //Console.WriteLine("Copied");
                      } else {
                          Console.WriteLine("No Copied");
                      /**forgot to close and paid the price when i couldnt delelete... **/
                      afile.Close(0);
          /** this took some reading to figure out... apparently it has to do with threading... **/
          public static Image collectIMGfromClipAndSave()
                       * ref - http://ryanfarley.com/blog/archive/2006/01/31/15840.aspx (*3)
                       * http://msdn.microsoft.com/en-us/library/system.windows.forms.clipboard.getimage.aspx?cs-sa ve-lang=1&cs-lang=csharp#code-snippet-2
                       * THIS WAS A GRADE A PAIN IN THE BUTT.....
                       * [STAThread] just above Main().... MAKES THIS WORK.....
                       * ouch my head hurts but is happy it works
                      ImageFormat theFormat = ImageFormat.Jpeg;
                      //System.Threading.Thread.Sleep(1000);
                      if (Clipboard.ContainsImage())
                          Image clipboardImage = Clipboard.GetImage();
                          return clipboardImage;
                      else
                          Console.WriteLine("nothing contained!!!");
                      return null;
          public static Image resizeImage(Image imgToResize, float width)
                      //http://tech.pro/tutorial/620/csharp-tutorial-image-editing-saving-cropping-and-resizing
                      int sourceWidth = imgToResize.Width;
                      int sourceHeight = imgToResize.Height;
                      float nPercent = 0;
                      /**convert sourcewidth to float and divide width to get percentage*/
                      nPercent=(width/(float)sourceWidth);
                      /** find new hight and width **/
                      int destWidth = (int)(sourceWidth * nPercent);
                      int destHeight = (int)(sourceHeight * nPercent);
                      /** start of create new image to return... */
                      Bitmap b = new Bitmap(destWidth, destHeight);
                      Graphics g = Graphics.FromImage((Image)b);
                      g.InterpolationMode = InterpolationMode.HighQualityBicubic;
                      g.DrawImage(imgToResize, 0, 0, destWidth, destHeight);
                      g.Dispose();
                      return (Image)b;
                  /** wrote this function so i could do overloads **/
                  private static void forpdftojpgFunc(string src, string outName, float w) {
                      Image image;
                      string newPath;
                      //Console.WriteLine("Copying page 1 of pdf");
                      methods.copyPdfCoverToClipboard(src);
                      image = methods.collectIMGfromClipAndSave();
                      image = methods.resizeImage(image, w);
                      newPath = Path.GetDirectoryName(src) + "\\" + outName + ".jpg";
                      image.Save(newPath);
                  public static void pdfPg1ToJPG(string src, float w)
                      forpdftojpgFunc(src, Path.GetFileNameWithoutExtension(src), w);
                  public static void pdfPg1ToJPG(string src, string outName, float w)
                      forpdftojpgFunc(src, outName, w);
          /************************ please note these are functions pulled form different files you will probably need to reorganize them to get them to work properlpy ***************/
          class Program
                  [STAThread]/**this makes the magic work I DONT KNOW WHY **/
                  static void Main(string[] args)
                      List<string> sources = new List<string>();
                      string outName = "";
                      if (args.Count() < 1)
                          Console.WriteLine("Enter A PDF");
                          sources.Add(Console.ReadLine());
                          Console.WriteLine("file out name");
                          outName = Console.ReadLine();
                      else {
                          for (int i = 0; i < args.Count(); i++)
                              sources.Add(args[i]);
                      Console.WriteLine("New Width:");
                      int width = Convert.ToInt16(Console.ReadLine());
                      foreach(string source in sources){
                          if (outName != "")
                              methods.pdfPg1ToJPG(source, outName, width);
                          else
                              methods.pdfPg1ToJPG(source, width);
          I know its not exactly what you are looking for but maybe it can help you in some way...
          I use it to make cover previews for the website in bulk or 1 at a time....
          I hope this helps....
