1 Reply Latest reply on Aug 16, 2012 1:16 PM by Yogesh Upadhyay
    Using multi-value properties in JSP components
    Xavier Beautoir Level 1
      I am trying to figure out if I am doing some small step wrong or if I don't have a full grasp on how some things work.
      I am accessing a multi-value property from the JSP of my component:
      <%@include file="/libs/foundation/global.jsp" %>
          <h2>Keys</h2>
          <div class="container_16">
              <div class="grid_8"><%
      Object keysObj = properties.get("keys");
      if (keysObj != null)
      String[] keys = (String[]) keysObj;
      <%= keys %><%
      } %></div>
      </div>
      Here is how I defined my component:
           "jcr:createdBy":"admin",
           "jcr:title":"My Listing",
           "allowedParents":["*/*parsys"],
           "componentGroup":"Listing Group",
           "sling:resourceSuperType":"foundation/components/parbase",
           "jcr:created":"Wed Aug 15 2012 20:01:15 GMT-0400",
           "jcr:primaryType":"cq:Component",
           "keys":[""]
      So keys is a multi-value String object. I am supposing the value is a String[].
      I created a dialog to set the values within the CQ page edit.
      - myList
      --- dialog [cq:Dialog]
      ----- items [cq:Widget]
      ------- items [cq:WidgetCollection]
      --------- tabs1 [cq:Panel]
      ----------- items [cq:WidgetCollection]
      ------------- keys [cq:Widget]
      The keys cq:Widget is defined as:
           "fieldLabel":"Keys to List",
           "xtype":"multifield",
           "name":"./keys",
           "jcr:primaryType":"cq:Widget",
           "fieldDescription":"List keys to display"
      I placed the component into an existing geometrixx page to test. When I double-clicked on it I was able to add multiple values.
      It is failing when I attempt to coerce the properties.get method to a String[]: String[] keys = (String[]) keysObj;
      16.08.2012 11:58:29.444 *ERROR* [10.176.196.66 [1345132705084] GET /content/geometrixx/en/services.html HTTP/1.1] com.day.cq.wcm.core.impl.WCMDebugFilter Error during include of SlingRequestPathInfo: path='/content/geometrixx/en/services/jcr:content/par/keylist', selectorString='null', extension='html', suffix='null' org.apache.sling.api.scripting.ScriptEvaluationException: An exception occurred processing JSP page /apps/myList/components/keyList/keyList.jsp at line 14
      <snip stack trace>
      Caused by: java.lang.ClassCastException: [Ljava.lang.Object; cannot be cast to [Ljava.lang.String;
      So all that leads to my question.
      It looks like I am wrong on how to coerce the results of properties.get to a String[]. What is the best way to work with multi-value properties? I want to iterate through the values in the multi-value property.
      Should I have specified the index in the method?
      ---- properties.get("keys[0]");
      Thanks!
