1. Re: Adobe Acrobat PDF DataBase Connection
manjeete Aug 17, 2012 3:22 AM (in response to manjeete)Hi Everybody,
Can i use SQL Server as my database? How PDF form will be connected to the database?
Manjeet
2. Re: Adobe Acrobat PDF DataBase Connection
manjeete Aug 17, 2012 4:08 AM (in response to manjeete)Hi Everbody,
I got a good article explaing PDF Forms + DataBase Connection. Follow the below link.
http://www.aces.edu/ctu/techref/software/acrobat/5.x/ADBC.pdf
Regards,
Manjeet
3. Re: Adobe Acrobat PDF DataBase Connection
Bernd Alheit Aug 17, 2012 11:24 AM (in response to manjeete)ADBC isn't available in the actual version of Adobe Acrobat.
4. Re: Adobe Acrobat PDF DataBase Connection
manjeete Sep 3, 2012 11:53 PM (in response to Bernd Alheit)Hi Bernd,
Can you please tell me, How an acrobat pdf forms will be connected to the sql server database?
Is it possible or not? If possible, can you please provide any sample or links?
Manjeet
5. Re: Adobe Acrobat PDF DataBase Connection
Dave Merchant Sep 4, 2012 12:14 AM (in response to manjeete)ADBC was depreciated in Acrobat 9 and removed completely in Acrobat X.
If you want users of Adobe Reader X to open database-connected forms you must use XFA and LiveCycle Designer to create them. If you intend to use Acrobat forms, the only database system available is SOAP (implemented via JavaScript) and that must be activated in Adobe Reader via the LiveCycle ES3 Reader Extensions server application - not with Acrobat.
6. Re: Adobe Acrobat PDF DataBase Connection
manjeete Sep 4, 2012 12:36 AM (in response to Dave Merchant)Hi Dave,
Thanks for replying. Can you provide any link for SOAP database system?
Manjeet
7. Re: Adobe Acrobat PDF DataBase Connection
Test Screen Name Sep 4, 2012 12:42 AM (in response to manjeete)SOAP is not actually a kind of database, it's a kind of network connection. You'd need (as well as LiveCycle Reader Extensions, please check pricing) a database which offers SOAP connections, or you'd write a server process for your database which offered SOAP connections.
8. Re: Adobe Acrobat PDF DataBase Connection
Test Screen Name Sep 4, 2012 12:44 AM (in response to Test Screen Name)Acrually, what you describe is a normal and very typical thing to do, and it is not done the way you describe. Forget all idea of directly writing the database on the user's computer unless your needs are very special and unusual.
Submitting a form means to connect to a web script (CGI, ASP, PHP...) on your web server, just like for any HTML form. The web script is responsible for adding to the database.
9. Re: Adobe Acrobat PDF DataBase Connection
stburden77 Dec 24, 2012 3:19 PM (in response to Test Screen Name)Happy Holidays To All:
I also need to connect an acrobat pdf form to a SQL Server database and LiveCycle is not an option.
We have a document manage software package that allows me to create pdf fillable forms for our users. The following is what I'd like to accomplish:
When the form loads, a "vendor name" dropdown box will be populated with distinct "vendor names" from our SQL Server database. The reason for this is so they don't key in different variations of the same vendor name. Currently, I'm using adobe pro X to create my forms and can upgrade to adobe pro XI if necessary.
Best regards
