12 Replies Latest reply on Aug 20, 2012 6:56 AM by VHC-CO-IT
    What should I upgrade next
    funkytwig Level 1
      Thank for everyones help so far.  It seems the computer I have is a .little under speced so I was wondering what I should consider upgrading next.  Memeory, CPU and GPU may be the answer but I am a student so need to take things slowly.
      I Cuppently have the following setup:
      GA-Z77-DS3H Motherboard
      Intel i5 3550 CPU
      16GB 1666 Memory
      550 Ti GPU
      I have odered a RAID0 DUAL drive enslosure and have 2*2TB Baracuda 72000 Drives.  Things generaly play without dropped frames in my current setup (FW800 Media Drive) so I dont think HD is the issue and when I get the new enclosure I will be more than doubeling disk throughput (I am editing DSLR/AVCHSD fottage whitch has a relativly low bandwidth).
      Alough it is not dropping frames playback is not ideal.  A lot of the time I have sync but it does tend to go out and I have ot stop/start to get it back. This has led me to think it is the CPU/GPU that I should consider upgrading next.  CPU is way under 50% so that makes me think GPU.  Is GPU used to play DSLR/AVCHD?
      So hat do people think?
      Ben
        • 1. Re: What should I upgrade next
          Harm Millaard Level 7
          Ben,
          Being a student on a limited budget (at least I was when I was a student) it is not bad. The thing is your disk setup is your limiting factor. You need three separate 7200 RPM SATA drives for decent editing and more is better. See Adobe Forums: Generic Guideline for Disk Setup
          Sure a better CPU can help, but the main issue is your current FW800 external connection. Getting an external raid raises the question which connection you will use for that box. If it is less than eSATA, it is again suboptimal.
          • 2. Re: What should I upgrade next
            RjL190365 Level 4
            Ben,
            With that i5-3550 CPU being only "limited"-overclockable, I would not go above a GTX 560 Ti or GTX 660 Ti for that system. You do want a good balance between the CPU and GPU in a video editing system.
            And I agree with Harm that your disk setup needs some improvement.
            • 3. Re: What should I upgrade next
              funkytwig Level 1
              As I said I was getting a RAID0 setup whitch shoud give me around 180MB/s, maybe more.  DSLR seem to be around 10MB/s so that gives an overhead of around 18 times.  I know to edit uncompressed you need a beafy system but the advantage of long GOP formats is they have low bitrates or am I missing something.
              Also what isa bit confusing is that I am not getting droped frames but the playback is not always in sync, does this tell me anything?
              Ben
              • 4. Re: What should I upgrade next
                That is only true if you use an eSATA connection. If you continue using FW800, you will not get more than 50-60 MB/s
                • 5. Re: What should I upgrade next
                  RjL190365 Level 4
                  True. The maximum theoretical bandwidth of a single FW800 connection is only 100 MB/s. (Remember, FW800 has a maximum theoretical bandwidth of 800 Mbit/s, which converts to 100 MB/s maximum -- 1 byte equals 8 bits.) Allowing for the overhead, this means the maximum practical bandwidth of the FW800 interface is only around 85 MB/s. (For comparison, the maximum practical bandwidth of a single eSATA 3.0 Gb/s connection is around 270 MB/s.)
                  • 6. Re: What should I upgrade next
                    Jim_Simon Level 9
                    The GPU isn't used for any playback.  It helps with effects, scaling, color space, resolution and frame rate differences, but decoding for playback is always handled by the CPU.
                    • 7. Re: What should I upgrade next
                      funkytwig Level 1
                      Indeed, its a USB3 enclosure, ive been caught out by this before.  The other question I did ask before was is it better to use the two Baracuda 7200 seperatly (one for media and one for PP gnerated 'preview' files) or have them configured as RAID0.
                      • 8. Re: What should I upgrade next
                        RjL190365 Level 4
                        Then it depends on many varibles: the controller inside the enclosure and the controller on your motherboard. Some USB 3.0 setups can barely reach 100 MB/s in maximum sustainable transfer speed; other combinations can reach at least 150 MB/s.
                        • 9. Re: What should I upgrade next
                          Jim_Simon Level 9
                          I'd go separate myself.
                          • 10. Re: What should I upgrade next
                            funkytwig Level 1
                            I am waiting for a replacement for one that had a loose power conection.  I did have it working and had 180MB/second but it was empty. I know with single drives the perfmance suffers badly when the drive starts to get full.  Is this the same wth RAID)?
                            • 11. Re: What should I upgrade next
                              RjL190365 Level 4
                              In your particular case, it's the single connection to an interface that's the limiting factor. RAID performance will be limited both by the controller and the number of connections to the same controller. Most external enclosures (and yes, even those with an internal RAID) make do with only a single connection to a given interface.
                              • 12. Re: What should I upgrade next
                                VHC-CO-IT
                                That isn't exactly the case.  The graphics card still has to put the pixels on the screen and refresh the frame and I kid you not, I've seen PCs too slow to do that.  Remember all those emachines and HP's that shipped out in 2008 with the geforce 6150 onboard?  They cannot play youtube videos at full screen without chopping frames in half and skipping even with a high powered dual athlon chip and tons of RAM.  They can't play DVDs or video files above about 640x480 either.  All programs use the graphics card to some extent but playback of an unmodified video clip requires practically no calculations, just the OS telling the graphics card to create the separate graphics layer and put it on the screen.  In your case, with the 550TI, it's fast enough to play anything though.
                                I don't think external media limitations would result in individual dropped frames though so I can't figure out what's causing your problem.  That would cause temporary pauses when the buffer in memory runs out (on long videos) but not frames to drop.
                                Luckily all actual Intel chipset-based controllers run at exactly the same speed since they're all exactly the same controller.  They're fast too.  Those dumpy aftermarket ones thrown on budget motherboards have severe performance issues though.  Some PCI-E controller cards don't do so well and some outperform the Intel versions so that's a real grab bag.
                                If you have a bunch of hard drives though, your PC probably has 1 SATAIII controller and 1 SATAII controller and that's it so the bandwidth is shared by all devices connected to them.  So because of that, I'd stick with USB3.0.  It's definitely not good enough for some sort of external RAID though, as it will hit the upper limit of speed really quickly and not perform at full speed.
