This content has been marked as final.
Show 4 replies
1. Re: Special characters (mdash)
Rothrock Feb 14, 2008 11:11 AM (in response to ewon15)Is your XML doc saved as UTF-8 format. That might fix it. -
2. Re: Special characters (mdash)
ewon15 Feb 14, 2008 11:19 AM (in response to Rothrock)yes, it is:
3. Re: Special characters (mdash)
Rothrock Feb 14, 2008 12:49 PM (in response to ewon15)Hmm...just having the statement at the beginning doesn't mean it is UTF-8 it requires actually changing some save settings. But at the moment I don't think that is the problem.
I tried to just assign the htmlText of a field placed on the stage at run time and — didn't work, but the others did. I'm guessing that it just isn't recognized.
Why don't you just use the actual character in your text. If you save as UTF-8 you don't need to use the fancy html codes for any of those things — unless of course you have < > which will confuse the XML into thinking there is another node. In that case you need to use CDATA to wrap your text entries. -
4. Re: Special characters (mdash)
ewon15 Feb 14, 2008 2:09 PM (in response to ewon15)hey, on another forum someone replied and said i should try using this character reference: —
it worked!
