0 Replies Latest reply on Aug 17, 2012 11:11 AM by efish11
    unable to get workflow id in ecma script
    efish11
      I am using the following ecma script in a OR split
      function check() {
         log.info("##########IN CHECK FUNCTION###########");
         var path=workItem.getWorkflow().getId() + "/metaData"
         var node=workflowSession.getSession().getItem(path);
         if (node.hasProperty("multipleapprovers")){
                   if(node.getProperty("multipleapprovers").getString() == "NOMOREREVIEWERS"){
                       return true;
                   }else{
                       return false;
      but i am seeing the following error in logs, I assumed workItem reference was provided to ECMA scripts
      Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "workItem" is not defined. (/etc/workflow/scripts/script2.ecma#5)
                at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3350)
                at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3340)
                at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRuntime.java:3413)
                at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java:1612)
                at org.mozilla.javascript.gen.c14._c1(/etc/workflow/scripts/script2.ecma:5)
                at org.mozilla.javascript.gen.c14.call(/etc/workflow/scripts/script2.ecma)
                at org.mozilla.javascript.optimizer.OptRuntime.callName(OptRuntime.java:97)
                at org.mozilla.javascript.gen.c14._c0(/etc/workflow/scripts/script2.ecma:20)
                at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:393)
                at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:2834)
                at org.mozilla.javascript.gen.c14.exec(/etc/workflow/scripts/script2.ecma)
                at org.mozilla.javascript.Context.evaluateReader(Context.java:1227)
                at org.apache.sling.scripting.javascript.internal.RhinoJavaScriptEngine.eval(RhinoJavaScript Engine.java:114)
                at org.apache.sling.scripting.core.impl.DefaultSlingScript.call(DefaultSlingScript.java:358)
      Any suggestions/pointers are appreciated
      Environment
      CQ 5.5, windows
