1 Reply Latest reply on Aug 17, 2012 3:09 PM by WebolutionDesigns
    Populating ComboBox with CFC web service return type query
    WebolutionDesigns
      I am just now learning Flex and am attempting my first app (I have been a CFer for years).
      Anyway, I am attempting to build an AIR app in Flex that simply has a login with a form to submit information into a database.
      Things are going ok, except I am stumped at something that I think should be simple...populating a combo box. I have a CFC (I am using CFCs as a web service to drive the app) that contains a method that simply returns a query. I want to use the results to populate the combo box display and value. I created the combo box and then dragged the method to the box to have FB create the code. It populates the list but with just [object Object]. This is a piece of cake in CF but I am not stumbling across the correct syntax in Flex. Any pointers would be appreciated.
      Here is my current code.
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                             xmlns:mx="library://ns.adobe.com/flex/mx"
                             xmlns:users="services.users.*"
                             currentState="login"
                             xmlns:vinlookup="services.vinlookup.*"
                             xmlns:inventory="services.inventory.*"
                             creationComplete="init()">
          <fx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.controls.Alert;
                  import mx.events.FlexEvent;
                  import mx.rpc.events.FaultEvent;
                  import mx.rpc.events.ResultEvent;
                  import mx.utils.ObjectUtil;
                  /*Login Code----------------------------------*/
                  private var loginrs:Object;
                  //Failed to connect to the wsdl service
                  private function GeneralFailed_Handler(e:FaultEvent):void
                      Alert.show(e.fault.faultString, "Error connecting to the service");
                  //Login Handler
                  protected function submitBtn_clickHandler(event:MouseEvent):void
                      loginUserResult.token = users.loginUser(userName.text, password.text);
                  //Result Handler for Account Authentication
                  private function loginUserResult_resultHandler(e:ResultEvent):void
                      //check the result
                      //Alert.show(ObjectUtil.toString(e.result),"Login Results")
                      loginrs = new Object();
                      loginrs = e.result;
                      if(loginrs['loggedin'] == 'Y')
                          currentState = 'insertInventory';
                      }else{
                          Alert.show("Try Again Please.");
                  /*VIN Lookup Code----------------------------------*/
                  private var vinrs:Object;
                  //VIN Lookup Handler
                  protected function VINSubmitbtn_clickHandler(event:MouseEvent):void
                      getvinInfoResult.token = vinlookup.getvinInfo(vin.text, "BASIC");
                  private function vinLookupResult_resultHandler(e:ResultEvent):void
                      //check the result
                      Alert.show(ObjectUtil.toString(e.result),"Lookup Results")
                      vinrs = new Object();
                      vinrs = e.result;
                      if(vinrs == null)
                          Alert.show("The VIN did not decode. Try Again Please.");
                      else
                          bodyStyle.text = vinrs['VARBODYSTYLE'];
                          //Alert.show("Yes!");
                  /*Item Type Combo Box Code----------------------------------*/
                  protected function comboBox_creationCompleteHandler(event:FlexEvent):void
                      getItemtypeResult.token = inventory.getItemtype();
          </fx:Script>
          <s:states>
              <s:State name="login"/>
              <s:State name="insertInventory"/>
          </s:states>
          <fx:Declarations>
              <s:CallResponder id="loginUserResult" result="loginUserResult_resultHandler(event)"/>
              <users:Users id="users" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
              <s:CallResponder id="getvinInfoResult" result="vinLookupResult_resultHandler(event)"/>
              <vinlookup:Vinlookup id="vinlookup" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
              <inventory:Inventory id="inventory" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
              <s:CallResponder id="getItemtypeResult"/>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:Panel width="250" height="150" title="Login" horizontalCenter="0" verticalCenter="0" includeIn="login">
              <mx:Form width="100%" height="100%" horizontalCenter="0" verticalCenter="0">
                  <mx:FormItem label="User Name">
                      <s:TextInput id="userName"/>
                  </mx:FormItem>
                  <mx:FormItem label="Password">
                      <s:TextInput id="password" displayAsPassword="true"/>
                  </mx:FormItem>
                  <mx:FormItem>
                      <s:Button label="Login" id="submitBtn" click="submitBtn_clickHandler(event)"/>
                  </mx:FormItem>
              </mx:Form>
          </s:Panel>
          <s:Panel includeIn="insertInventory" width="400" height="400" title="Insert Inventory" horizontalCenter="0" verticalCenter="0">
                  <mx:FormItem label="VIN">
                      <s:TextInput id="vin"/>
                  </mx:FormItem>
                  <mx:FormItem id="vinSubmitbtn">
                      <s:Button label="Decode VIN" id="VINSubmitbtn" click="VINSubmitbtn_clickHandler(event)"/>
                  </mx:FormItem>
                  <mx:FormItem label="Body Style">
                      <s:TextInput id="bodyStyle"/>
                  </mx:FormItem>
                  <mx:FormItem label="Item Type">
                      <s:ComboBox id="comboBox" creationComplete="comboBox_creationCompleteHandler(event)">
                          <s:AsyncListView list="{getItemtypeResult.lastResult}"/>
                      </s:ComboBox>
                  </mx:FormItem>
              </mx:Form>
          </s:Panel>
      </s:WindowedApplication>
