5 Replies Latest reply on Sep 3, 2012 6:38 AM by Michael Orzechowski
    Trial Reader Extensions credentials error
    Michael Orzechowski Level 1
      Hello experts
      I have just installed Windows x64 turnkey version of LC server.
      I got some errors during installation (admittedly I should have make a note of these, sadly I havent) however these were not particulary descriptive so I have decided to continue and see if I will be able to fix these later.
      At the moment I only had a look at admin console (seems to work fine) and I tried to launch Reader Extensions module but latter does not want to start. After logging in I am presented with following message:
      Application alert
      A fault occured while trying to access the list of Reader Extensions credentials
      and subsequently I am being logged off.
      I tried to find the cause of that issue in Trust Store to no avail.
      Can anyone help?
      Regards
      Michael
        • 1. Re: Trial Reader Extensions credentials error
          TundraSteve Employee Moderator
          I'd recommend restarting the server and checking the server log for errors.  Also, have you installed the RE cert in the trust store as a local credential it should look like the following:
          ARES
          C=US,O=Adobe Systems Incorporated,OU=Adobe Trust Services,CN=ARE IDev V6.1 P19 0009278
          CN=Product Services,OU=Adobe Trust Services,O=GeoTrust Inc.,C=US
          Tuesday, December 6, 2011
          • 2. Re: Trial Reader Extensions credentials error
            Steve
            Thanks for your suggestions.
            Please find a little more information about my local server.
            My Local Credentials are as follows:
            ARES C=US,O=Adobe Systems Incorporated,OU=Adobe Trust Services,CN=ARE IDev V6.1 P19 0009278 CN=Product Services,OU=Adobe Trust Services,O=GeoTrust Inc.,C=US Tuesday, 6 December 2011 07:31 to Tuesday, 31 December 2013 15:52
            As for server logs I had a look at few and I can see some errors, its just that these does not mean much to me, perhaps someone can help to decypher them?
            .../configurationManager/log/lcm.0.log
            com.adobe.idp.DocumentError: java.net.SocketException: Unexpected end of file from server at com.adobe.idp.DocumentManagerClient.clientSidePush(DocumentManagerClient.java:446)
            SEVERE, Thread-8, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Failed to deploy component C:\Adobe\Adobe LiveCycle ES3\deploy\adobe-pdfservices-dsc.jar
            SEVERE, Thread-8, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Failed to deploy component C:\Adobe\Adobe LiveCycle ES3\deploy\adobe-scheduler-jboss-dsc.jar.
            SEVERE, Thread-8, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Failed to deploy component C:\Adobe\Adobe LiveCycle ES3\deploy\adobe-workflow-dsc.jar.
            SEVERE, Thread-8, com.adobe.livecycle.lcm.feature.deployment.DeployDSCs, Failed to deploy component C:\Adobe\Adobe LiveCycle ES3\deploy\adobe-repository-dsc.jar.
            .../jboss/server/lc_turnkey/server.log
            ERROR [STDERR] (error stream consumer for cmd: cmd.exe /c rmdir /s /q C:\Windows\Temp\adobejb_server1) C:\Windows\Temp\adobejb_server1\ARCHIV~1\111\com\adobe\PRINTS~1\PROPER~1\eclipse -
            ERROR [STDERR] (IDPSchedulerService_Worker-1) com.adobe.idp.common.errors.exception.IDPLoggedException| [com.adobe.idp.storeprovider.jdbc.DBStoreFactory] errorCode:12290 errorCodeHEX:0x3002 message:initialization failurecom.adobe.idp.common.errors.exception.IDPLoggedException| [com.adobe.idp.storeprovider.jdbc.DBStoreFactory] errorCode:12290 errorCodeHEX:0x3002 message:no setup for com.adobe.edc.server.spi.storage.entity.PolicyEntity
            ERROR [STDERR] (IDPSchedulerService_Worker-1)           at com.adobe.idp.storeprovider.database.DBProviderCache.initialize(DBProviderCache.java:175)
            ERROR [STDERR] (IDPSchedulerService_Worker-1)           at com.adobe.idp.storeprovider.database.DBProviderCache.getStoreProvider(DBProviderCache.jav a:135)
            ERROR [STDERR] (IDPSchedulerService_Worker-1)           at com.adobe.rightsmanagement.license.dao.impl.BaseDAOImpl.getStoreProvider(BaseDAOImpl.java :19)
            ERROR [STDERR] (IDPSchedulerService_Worker-1)           at com.adobe.rightsmanagement.license.dao.impl.PrincipalKeyDAOImpl.findAllKeysToRollover(Pri ncipalKeyDAOImpl.java:144)
            ERROR [STDERR] (IDPSchedulerService_Worker-1)           at com.adobe.rightsmanagement.license.service.impl.LicenseServiceImpl.findAllKeysToRollover( LicenseServiceImpl.java:664)
            ERROR [STDERR] (IDPSchedulerService_Worker-1)           at com.adobe.edc.server.businesslogic.license.LicenseManagerBean.findAllPrincipalKeys(Licens eManagerBean.java:1978)
            .../jboss/server/lc_turnkey/boot.log
            Error deploying: file:/C:/Adobe/Adobe%20LiveCycle%20ES3/jboss/server/lc_turnkey/conf/bootstrap/vfs.xm at org.jboss.deployers.spi.DeploymentException.rethrowAsDeploymentException(DeploymentExcept ion.java:49)
            Error deploying: file:/C:/Adobe/Adobe%20LiveCycle%20ES3/jboss/server/lc_turnkey/conf/bootstrap/logging.xml at org.jboss.deployers.spi.DeploymentException.rethrowAsDeploymentException(DeploymentExcept ion.java:49)
            Thanks in advance for any help/suggestions
            • 3. Re: Trial Reader Extensions credentials error
              I have decided to install clean OS (W7 x64) and after that ES3 turnkey deployment went fine. All the modules installed seem to be working (touch the wood). The only problem I got was when I've decided to add some module using Configuration Manager. I got some nasty and not awfully descriptive errors. I have then un-installed whole suite and install it again (this time with the module I was after).
              Pity that errors thrown during installation were not particularly meaningful, system on which I have been trying to install it before is successfully hosting couple other servers and several applications (many of them Adobe) so I cant see why ES3 would not be able to deploy there.
              Anyway, my advice to anyone who is struggling with installation of that trial: use VMWare Player, setup clean OS and install ES3 on VM.
              • 4. Re: Trial Reader Extensions credentials error
                N Santosh Kumar Adobe Employee
                Michael,
                Please attach the logs if you have from your previous setup which ran in to issues , Did that server had previous versions of Adobe LiveCycle running on it?
                Are there are any issues with the current installation on clean system ?
                • 5. Re: Trial Reader Extensions credentials error
                  Santosh
                  I am afraid I dont have logs anymore, I have however included some snippets (see my message from 20th of August) with lines that included keywords like "failed" or "error".
                  That particular laptop had no previous version of LiveCycle.
                  Regards
                  Michael
