4 Replies Latest reply on Aug 21, 2012 8:23 AM by alexanderklapfer
    Copy to new artboard with transformation in VBA
    alexanderklapfer Level 1
      Hallo Forum,
      I have the common problem to resize the artboard to standardize technical illustrations to the format 50x50mm. So I found good help in the forum (thank you). I have some problem and may somebody can help me:
      • I would like to group the objects for further transformations
      • I would transform the group to 45mm and scale stroks and effects
      N.B.: here It should be a test on landscape format
      • I would align the group to the page center
      This is my code, may somebody can help me ?
      Thank you to every replay
      Regards Alex
      Public Sub copy_paste_with_transformation ()
      'Duplicates grouped items in a new document with landscape sensitive transformation
      Set appRef = CreateObject("Illustrator.Application")
      'calculate the size of objects do define if it's landscape or not
      Bounds = appRef.ActiveDocument.VisibleBounds
      'If the group is landscape the lenth should be 45mm otherwise the higth
      appRef.ActiveDocument.GroupItems 'problem
      appRef.ActiveDocument.SelectObjectsOnActiveArtboard 'may a solution for CS4 too
      appRef.ActiveDocument.Resize(45, 45) 'problem
      appRef.ActiveDocument.copy
      Set newDocument = appRef.Documents.Add(aiDocumentCMYKColor, 50, 50) 'Paper size is 50mm
      newDocument.Paste
      'Align group to page center hrizontal and vertical
      End Sub
