I'm using RH9 on projects that were formerly processed by RH5. We have several single
projects that are then merged into one large project.
When I now start RH9 on an .xpj and generate the primary layout (Microsoft HTML Help),
I'm getting an error box saying "ungültige Medien.Datei. <path>\xyz.chm kann nicht erstellt werden".
Would it be better to switch to RH9 with english installed? If it would be better to solve
problems, I will do. Would I have to reinstall RH9 then? Or is there a dynamic way to switch between languages?
Christoph
Hi Chris,
Can you please let me know if you have these CHM file located in Shared drive??
Priyank
Priyank Srivastava wrote:
Hi Chris,
Priyank
Hi Priyank,
the history is the following: our secretaries who were using the project initially and were running in all sorts of trouble, are indeed using the project from a network drive ( net use h: \\server\share\...).
To examine their problems I moved the whole project tree to my local drive and presently I have
all sorts of hardwired h:\... paths in my project include files etc.
But at the moment with the problem appearing I have evrything on my local C: drive.
Christoph
Can you please change the location of the output to "C:\New folder\ " and then generate it. Please let me know if that helps.
Priyank
Priyank
OK. Thanks. That worked. I had a wrong, not existing drive in path in there.
