4 Replies Latest reply on Aug 23, 2013 2:54 PM by TheDano99
    PluralEyes aspect ratio problem in CS6
    Random Viking
      When attempting to sync a couple of mts files (Sony) with a separate audio track using PluralEyes, the files are synced with the audio but the aspect ratio is changed from 16:9 to 4:3 (squished vertically)
      Using Modify>Interpret footage, I can partially correct the problem by changing the pixel size to 1.33 but the aspect ratio remains unchanged, i.e. video on each side is clipped.
      I contacted the folks at Pluraleyes and their response (after sending them the log files) was that "this is a problem in Premiere Pro", which doesn't do me any good.  They stated that this will  occur on any export and reimport of an XML file from Premiere Pro involving mts files.
      Any suggestions?
        • 1. Re: PluralEyes aspect ratio problem in CS6
          Greg Baber Adobe Employee
          Can you post a screen shot of the footage that is brought into Premiere before interpreting it, and after?
          • 2. Re: PluralEyes aspect ratio problem in CS6
            H_DOS Level 1
            I have had the same problem. All i could do was select the first clip on the timeline, under modify click 'uniform scale', then control click the clip and selct copy. Then select the rest of the clips on the timeline and control click them  and select 'past attributes'.  Now all the clips are the right ratio.
            Hope this helps you.
            H
            • 3. Re: PluralEyes aspect ratio problem in CS6
              Shadreck Rukweza Level 2
              Is this on windows or Mac?
              • 4. Re: PluralEyes aspect ratio problem in CS6
                TheDano99
                I have the same problem too-- but when I did clip/ modify / interpret footage / Use Pixel Aspect Ratio from File: HD Anamorphic 1080 (1.33), it still keeps video 2 at (1.0). Windows.
                So, here's what I did that seems to fix everything. In the first example above, I hit "cancel" on the way in to creating the project in order to avoid picking a preset for the sequence. When I imported the footage, I created a sequence based on that footage.
                However! When I found the preset based on my cameras output (AVCHD 1080i30 (60i) Anamorphic), I then created a new sequence with that preset, copied the media files to the timeline, hit save, export to FCP xml, and then ran Pluraleyes (v2), it worked perfectly. I'm guessing the problem is that PluralEyes is guessing wrong as to the pixel ratio for some reason.
                Also, I believe I should be able to run PluralEyes from within Premiere Pro, but I don't see a menu item for it...anyone know about that off hand?
