5 Replies Latest reply on Aug 21, 2012 9:04 AM by Curt Y
    What is the best way to process files in CS5 jpeg, tiff, or psd
    capt marvy
      My camera out put is in Jpeg I have no choice. While I can process jpeg with no problems in CS5 is there a better way to do this? would I be better off converting the jpeg to either tiff or psd and then process the file and then reconvert back to jpeg as the final product. I have heard so much about "lossy"(jpeg) vs "non Lossy" (tiff and psd) which are the ones I want to use? Am I on the right track
      Capt M
        • 1. Re: What is the best way to process files in CS5 jpeg, tiff, or psd
          gener7 Adobe Community Professional & MVP
          Wayne Fulton has some excellent advice and covers this topic well.
          http://www.scantips.com/basics09.html
          Aside from that always set your camera to the best quality jpeg setting. Converting to lossless formats does not lose jpeg artifacts if the image was low quality jpeg to begin with.
          • 2. Re: What is the best way to process files in CS5 jpeg, tiff, or psd
            capt marvy Level 1
            Gener7,
            Thank you for your informative article....The thing I guess I did not see was if I move a jpeg file from one folder to an other does that create problems as well. In other words downloading from camera to pc..once it in the pc and transfer it to folder for processing is there any loss there. I believe you are right about taking taking a low quality shot ( a 1megapixle output and trying make a 14 megapixle on the pc. You can see the artifacts real quick. So answer me with this one question is there loss transfering a jpeg file from one folder to an other
            Capt M
            • 3. Re: What is the best way to process files in CS5 jpeg, tiff, or psd
              No,the loss comes in reediting and resaving the jpeg,not transferring it.
              More information:
              http://graphicssoft.about.com/od/formatsjpeg/a/jpegmythsfacts.htm
              One last thing, Resolution and jpeg quality are two different settings in your camera.
              640 x 480 pixel settings would be low resolution,while 3000 x 2000 (6MP) would be max resolution in some cameras.  Pick the highest setting. Better to reduce than enlarge. Overhead is good.
              Jpeg quality would be something like lowest to highest jpeg compression setting,but it's usually described as Normal,Fine,and Superfine. Take "Superfine". Most storage cards have much more capacity today and it isn't as costly.
              Gene
              • 4. Re: What is the best way to process files in CS5 jpeg, tiff, or psd
                capt marvy Level 1
                Gene,
                You have been most helpful....what I think you are saying is....on my camera which is a canon sx30is is 14 megapixles/with fine setting, is to set the camera to max with a fine setting download to pc, reduce the the size, edit the image as needed once or twice, set the storage file to max quality and store it for future use. Is this what you saying? Good then you have reduced my work load!!
                Capt M
                • 5. Re: What is the best way to process files in CS5 jpeg, tiff, or psd
                  Curt Y Level 7
                  A touch of realism from me.  If you are going to make enlargments less then 11x17 a person would have a hard time telling the difference between Normal and Superfine jpeg settings.  Same with saving jpeg with 9 vs 12 quality settings.  But there is a significant difference in file size between 9 and 12.  So the expected end use, and how much hard drive space you want to devote is the real driver.
                  If you were a perfectionist you would burn the original to several disks and archive in different places (and resave evey few years to minimize degredation).   Then with the copy you can save smaller flies knowing if you have a need you have the original at HQ saved.
