5 Replies Latest reply on Dec 21, 2012 9:18 PM by Sham HC
    /libs/cq 404 error
    stewa52
      I am getting a 404 for my pages when trying to download the userinfo.json and dict.en.json from /libs/cq folder.  What causes those two files to be included?
        • 1. Re: /libs/cq 404 error
          Sham HC Level 7
          The servlets [1] are responsible for rendering requests to userinfo.json and dict.en.json.  Make sure the bundles [2] & its respective components are active.   If it is active I am assuming the dispatcher filter might be blocking it.   These files are included part of [3].   In case you you don't need the userinfo and i18n data for your site then do[4].
          [1]
          com.day.cq.security.widgets.impl.UserInfoServlet
          com.day.cq.i18n.impl.ResourceBundleExportServlet
          [2]
          com.day.cq.cq-security
          com.day.cq.cq-i18n
          [3]  /etc/clientlibs/foundation/shared/source/init.js
          [4]
          *   From crxde at publish instance Comment out below lines in [3]
          // CQ.shared.User.init();
          // CQ.shared.I18n.init({locale: CQ.shared.User.getLanguage()});
          *    Clean and save /var/clientlibs/etc
          • 2. Re: /libs/cq 404 error
            huijun.chua
            Hi Sham,
            Our website does not need the userinfo and i18n data and therefore the dispatcher filter is also configured to block this. We have tried [4] in your suggested solution but it only seems to solve the 404 error for userinfo.json but not dict.en.json.
            Could there by anywhere else that is also calling dict.en.json?
            • 3. Re: /libs/cq 404 error
              Sham HC Level 7
              Apart from this I can think out of default is teaser component. Are you using teaser component ?
              • 4. Re: /libs/cq 404 error
                djain5
                Hi Sham,
                How is teaser component related to Userinfo.json and dict.en.json?
                I am using teaser compoent but that is customized one
                • 5. Re: /libs/cq 404 error
                  Sham HC Level 7
                  It is long time I could not recall. Verify yourself by verfying a page that does not have teaser component.
