9 Replies Latest reply on Aug 27, 2012 8:44 AM by kemch1013
    "Not a Valid Signature" after installing the patch.
    kemch1013 Level 1
      I'm trying to install the GuideGuide extension for CS5 and keep getting the "Not a valid signature". I installed the patch that claims to fix the problem, but it's not working. What else can I do so I can get this extension working? Please help!
      OS X Lion 10.7.4, Photoshop CS5 12.0.4 x64, Extension Manager CS5 5.0.334
        • 1. Re: "Not a Valid Signature" after installing the patch.
          Carl Sun Level 4
          You said you had installed the patch, but the version of Extension Manager (5.0.334) indicated that you have NOT installed the patch. After update the version should be 5.0.2.27. Please download and install http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/AdobeExtensionManager _5_0_2_mul_AdobeUpdate.dmg then retry. This link can be found at http://www.adobe.com/downloads/updates/. You can also use Adobe Application Manager to update many Adobe products to the latest version.
          • 2. Re: "Not a Valid Signature" after installing the patch.
            kemch1013 Level 1
            Thanks for the reply. I installed the patch at the URL several times, all which finish successfully, but I am consistently at version 5.0.334.
            I looked at the updates linlk and saw there was an Extension Manager 5.0.3 update. Do I need to install this? Adobe Updater shows no available updates on my side.
            Are you suggesting I roll back to version 5.0.2.27? How would I go about doing that?
            • 3. Re: "Not a Valid Signature" after installing the patch.
              Xiaoyi Tong Adobe Employee
              Hi Kemch,
              Extension Manager 5.0.3 update is for Mac 10.8 only. That is why Adobe Update does not show it on your side. The version you are using is 5.0.334, which is  older than 5.0.2.27. So it is not rolling back, but upgrading.
              One thing we want to confirm with you is, was your issue( "not a valid signature" ) sovled after you installed 5.0.2.27? If the issue was solved, it means the update works. We will try it on our side to make sure if it is a general issue. Thanks.
              • 4. Re: "Not a Valid Signature" after installing the patch.
                kemch1013 Level 1
                Hello, thank you for the followup.
                I can confirm that it is not working, because I end up with the same results when attempting to apply the 5.0.2.27 patch. Some screenshots below to show the order of things. No change when restarting system or software.
                Here is the patch:
                http://cl.ly/image/333I2I263P1M
                Installs ending with a message "update complete":
                http://cl.ly/image/2C1U0v193R00
                Upon opening the Extension Manager. Version still says 5.0.334.
                http://cl.ly/image/3m0a2j2Y0z1Q
                Adding the guideguide extension throws me the "Valid Signature" error.
                http://cl.ly/image/3D1S2T0X2N0a
                • 5. Re: "Not a Valid Signature" after installing the patch.
                  kemch1013 Level 1
                  I tried installing this again today and noticed something I didn't before.
                  It looks like the installation fails, but the patch installer still says successful in the end. You can see a warning icon flash very quickly between the progress bar and the success message. See the screen recording: http://cl.ly/2Q0O3u340Q0z
                  Any suggestions on what to do?
                  • 6. Re: "Not a Valid Signature" after installing the patch.
                    Carl Sun Level 4
                    Have you ever deleted any files (such as localized resource files) under Extension Manager folder? There has been some users failed to apply update because of this reason. You can generate update log file and paste the file here.
                    1. Open a Terminal window.
                    2. Run command: cd /tmp
                    3. Run command: touch ribs3debug
                    4. After that a new file named "ribs3debug" should have been created in /tmp folder.
                    5. Update Extension Manager, via Adobe Application Manager or running updater installer manually.
                    6. The new log file "/Library/Logs/Adobe/Installers/Adobe Extension Manager CS5 xxx 08-24-2012.log.gz" will be created. (xxx is the version number)
                    7. Unzip the actual log file from this file.
                    • 7. Re: "Not a Valid Signature" after installing the patch.
                      kemch1013 Level 1
                      Thank you for the help. Followed the instructions and have this log file:
                      Visit http://www.adobe.com/go/loganalyzer/ for more information
                      START - Installer Session
                      RIBS version: 5.0.65.0
                      OSX version: 10.7.4
                      ::START TIMER:: [Total Timer]
                      CHECK: Single instance running
                      CHECK : Credentials
                      Load Deployment File
                      deploymentFile option not given
                      CHECK : Another Native OS installer already running
                      Create Required Folders
                      Assuming install mode
                      Looking up install source path
                      Sync Media DB ...
                      ::START TIMER:: [Sync Media DB]
                      Pre check media db sync
                      End of Pre check media db sync. Exit code: 0
                      :: END TIMER :: [Sync Media DB] took 73 milliseconds (0.073 seconds)
                      Ready to initialize session to start with ...
                      ::START TIMER:: [CreatePayloadSession]
                      -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
                      Updated source path: /Volumes/AdobeExtensionManager-5.0.2-mul-AdobeUpdate
                      Updating media info for: {C24D91B7-406B-4C50-879A-44478359B772}
                        Type: 1, Volume Order: 1, Media Name: AdobeExtensionManager-5.0.2-mul-AdobeUpdate
                        Path: /Volumes/AdobeExtensionManager-5.0.2-mul-AdobeUpdate/payloads/AdobeExtensionManager5.0All -011211025639/AdobeExtensionManager5.0All-011211025639.dmg
                      --------------------  END  - Updating Media Sources -  END  --------------------
                      Supported RIBS version range: [0.0.66.0,5.0.65.0]
                      ----------------- CreatePayloadSession: machine is x86 ---------------
                      [       0] Fri Aug 24 07:55:15 2012  INFO
                      ______ Verify Dependency Subscribers ______
                      BEGIN Operation order for all session payloads: mediaGroup (requires,satisfies)
                        {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0: 0 (0,0)
                      END Operation order for all session payloads: mediaGroup (requires,satisfies)
                      Initializing the INSTALLDIR with PDB data for payload {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
                      File Exists: /Applications/Adobe Extension Manager CS5/Adobe Extension Manager CS5.app/Contents/Resources/AMT/application.xml
                      Located the INSTALLDIR for payload '{E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}' : '/Applications'
                      Overwrite property "DEVersion" to: 5
                      Overwrite property "extensionsOnly" to: 1
                      Overwrite property "mode" to: silent
                      Overwrite property "patchesOnly" to: 1
                      Overwrite property "workflow" to: updater
                      Found payload actions:
                      Deciding what installer mode to use...
                      Initializing the INSTALLDIR with PDB data for payload {C24D91B7-406B-4C50-879A-44478359B772}
                      Located the INSTALLDIR for payload '{C24D91B7-406B-4C50-879A-44478359B772}' : '/Applications'
                      BEGIN Setting requested payload actions
                      Value returned on lookup of payload: {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0 is: true
                      Action string for {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0  is install
                      END Setting requested payload actions
                      Collected advanced path check information for INSTALLDIR
                      INSTALLDIR is a well-formed path
                      INSTALLDIR is not the root path
                      INSTALLDIR is on a local volume
                      INSTALLDIR is on a writable volume
                      INSTALLDIR is not on a case sensitive volume
                      INSTALLDIR passed path basic path validation: /Applications
                      [       0] Fri Aug 24 07:55:23 2012  INFO
                      BEGIN InstallOperationsQueue Unordered operations
                        {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0:  with operation repair
                      END InstallOperationsQueue Unordered operations
                      BEGIN InstallOperationsQueue Ordered operations
                      END InstallOperationsQueue Ordered operations
                      [       0] Fri Aug 24 07:55:23 2012  WARN
                      DW035: Patcher: {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0 has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
                      Payloads passed preflight validation.
                      Call PreSession Custom Hook
                      Skipping payload {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0 as payload is not cached
                      No operation.  We're done:
                      [       0] Fri Aug 24 07:55:25 2012  INFO
                      Total components installed: 0
                      Total components repaired: 0
                      Total components removed: 0
                      [       0] Fri Aug 24 07:55:25 2012 ERROR
                      DW050: The following payload errors were found during install:
                      DW050:  - Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All: Patch already installed
                      Call PostSession Custom Hook
                      :: END TIMER :: [Total Timer] took 19706 milliseconds (19.706 seconds) DTR = 2.84177 KBPS (0.00277517 MBPS)
                      -------------------------------------- Summary --------------------------------------
                      - 0 fatal error(s), 1 error(s), 2 warning(s)
                      WARNING: DW035: Patcher: {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0 has already been applied. Patchers cannot be repaired/reinstalled, skipping this patcher
                      ERROR: DW050: The following payload errors were found during install:
                      ERROR: DW050:  - Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All: Patch already installed
                      Please search the above error/warning string(s) to find when the error occurred.
                      These errors resulted in installer Exit Code mentioned below.
                      Exit Code: 32 - The patch is already applied.
                      Please see specific errors and warnings for troubleshooting. For example, ERROR: DW050 ... WARNING: DW035 ...
                      END - Installer Session
                      OSX version: 10.7.4
                      CHECK : Credentials
                      Sync Media DB ...
                      :: END TIMER :: [Sync Media DB] took 48 milliseconds (0.048 seconds) DTR = 83.3333 KBPS (0.0813802 MBPS)
                      [       0] Fri Aug 24 07:56:29 2012  INFO
                      [       0] Fri Aug 24 07:56:29 2012  WARN
                      [       0] Fri Aug 24 07:56:30 2012  INFO
                      [       0] Fri Aug 24 07:56:32 2012  INFO
                      [       0] Fri Aug 24 07:56:32 2012 ERROR
                      :: END TIMER :: [Total Timer] took 15968 milliseconds (15.968 seconds) DTR = 22.2946 KBPS (0.0217721 MBPS)
                      OSX version: 10.7.4
                      CHECK : Credentials
                      Sync Media DB ...
                      :: END TIMER :: [Sync Media DB] took 8 milliseconds (0.008 seconds)
                      [       0] Fri Aug 24 07:59:03 2012  INFO
                      [       0] Fri Aug 24 07:59:04 2012  INFO
                      [       0] Fri Aug 24 07:59:04 2012  WARN
                      [       0] Fri Aug 24 07:59:06 2012  INFO
                      [       0] Fri Aug 24 07:59:06 2012 ERROR
                      :: END TIMER :: [Total Timer] took 13596 milliseconds (13.596 seconds) DTR = 1.17682 KBPS (0.00114924 MBPS)
                      OSX version: 10.7.4
                      CHECK : Credentials
                      Sync Media DB ...
                      :: END TIMER :: [Sync Media DB] took 10 milliseconds (0.01 seconds)
                      [       0] Fri Aug 24 08:00:28 2012  INFO
                      [       0] Fri Aug 24 08:00:29 2012  INFO
                      [       0] Fri Aug 24 08:00:29 2012  WARN
                      [       0] Fri Aug 24 08:00:31 2012  INFO
                      [       0] Fri Aug 24 08:00:31 2012 ERROR
                      :: END TIMER :: [Total Timer] took 10954 milliseconds (10.954 seconds) DTR = 6.20778 KBPS (0.00606228 MBPS)
                      OSX version: 10.7.4
                      CHECK : Credentials
                      Sync Media DB ...
                      :: END TIMER :: [Sync Media DB] took 13 milliseconds (0.013 seconds)
                      [       0] Fri Aug 24 08:33:02 2012 DEBUG
                      Payload located at potential path. Ignoring media info.
                      [       0] Fri Aug 24 08:33:02 2012  INFO
                      InstallerSession.CreatePayloadSession: Checking for unsupported payloads
                      ______ InstallerSession.CreatePayloadSession: Checking session payloads ______
                      InstallerSession.CreatePayloadSession: Load PDB
                      [       0] Fri Aug 24 08:33:05 2012 DEBUG
                      ______ InstallerSession.CreatePayloadSession: Checking incompatible payloads ______
                      ______ GetIncompatiblePayloadBuildsInstalled ______
                      ______ InstallerSession.CreatePayloadSession: Checking already installed payloads ______
                      {007A2A28-D6A8-4D91-9A2B-568FF8052215} Adobe WinSoft Linguistics Plugin CS5
                      {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper
                      {025363D2-CB60-4869-96B6-C6160D00E2F3} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.4_AdobePremierePro5ProtectedWrapperAll
                      {0256558F-A0FF-4FCF-99C2-96D2EE3201D9} Suite Shared Configuration CS6
                      {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5
                      {03740852-60C2-4B1A-A3DA-1EDB082C6401} Adobe Linguistics CS6
                      {0377892E-FCAC-46EC-AA70-C6AC8A86A81F} Dynamic Link Media Server
                      {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all
                      {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages
                      {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support
                      {0C4E7429-E920-4125-980E-029A87AE0A4D} AdobeColorCommonSetCMYK CS6
                      {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5
                      {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content
                      {148542D8-49CA-482A-A334-1D54C5A9D53B} Adobe XMP Panels
                      {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack
                      {18B12757-2C22-44CA-B1B7-E6C6A0639F46} Adobe Media Encoder CS5 Dolby WRAPPER
                      {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper
                      {1B947DEB-869E-4DA3-8368-64A79749384D} Adobe Media Encoder CS5 PCI WRAPPER
                      {1CB2200F-16E5-49DF-B280-2E52254DE033} Adobe Media Encoder CS5 PCI_5.0.1_AMEPCI5All
                      {1DA9F06C-F5A2-439C-88E0-642A4BE46AB0} Adobe Media Encoder CS5 Dolby_5.0.1_AMEDolby5All
                      {1EC2407F-6A7B-4A3C-9F46-C812EE3D44FD} HIL Help Search
                      {1F955A4A-F365-4379-AEE2-B7C83E1AA883} Adobe Photoshop CS6 Support
                      {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper
                      {2267CC22-3159-4AE6-AE54-C0C67C8E404B} Adobe After Effects CS5_10.0.2_AdobeAfterEffects10AllTrial
                      {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul
                      {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper
                      {2591B843-8028-4395-9DEE-03AF8D631539} Adobe Player for Embedding 3.3
                      {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US
                      {26F763C9-076F-473D-9A0E-4050C973737C} AdobeColorJA CS6
                      {273F2A32-EC95-4AF7-BF26-EF4A57368DC9} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul
                      {298CF0B0-8B47-46DF-B726-8E4BFAD5432E} AdobeHelp
                      {2996CAAB-680B-42DE-A798-B2871F93ED14} Pixel Bender Toolkit_2.5_aifsdk-mac
                      {2AF31A97-817A-4D06-8210-4F789A0FF908} Adobe After Effects CS5 Third Party Content_10.0.2_AdobeAfterEffects10ProtectedAll
                      {2C8C0585-5083-4032-94B8-A9AD04ED0716} Adobe AIR
                      {2D5B4A04-0A9F-4FB9-862A-C49400325A90} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack
                      {2F595448-AD13-4615-820A-15F141F762E8} Photoshop Camera Raw_6.6_AdobeCameraRaw6.0All
                      {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro
                      {3071EDD7-EA5B-4CAC-B4D0-4D4D664154D1} Adobe Photoshop CS6 English Language Pack_AdobePhotoshop13-en_US
                      {311CDC89-AC18-4344-9EC9-0225328C73D3} Required Common Fonts Installation
                      {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5
                      {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack
                      {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6
                      {379B5E99-3A86-4388-96AE-544950E08947} Adobe Media Encoder CS5 Dolby WRAPPER_5.0.1_AMEDolbyWrapper5All
                      {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw
                      {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK
                      {3E7A8DA8-0298-42F2-B927-4DB00E2F8FEE} DeviceCentral_DeviceCentral3LP-en_US
                      {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper
                      {42CCA701-73BF-48D4-86DA-27AE807163EF} Adobe Player for Embedding_3.1_AdobeAPE3-mul
                      {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5
                      {4482EF4A-376B-46DE-9B17-E377232328E0} PDF Settings CS6
                      {463D65D7-CD43-4FAC-A6C7-7D24CB5DB93B} Adobe Media Player
                      {4687A306-D716-4D7A-B0AA-EAB65D17F149} Adobe Player for Embedding
                      {47DF3210-E261-4D06-A073-92F6C426C352} Adobe Media Encoder CS5
                      {4822EB30-22F2-48A8-9B15-C6DF34BA9CE4} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack
                      {48623899-C152-457D-9B30-1F957332AC2F} AdobeColorPhotoshop CS6
                      {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper
                      {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5
                      {4F427880-01EA-4E0F-AAE2-9ADE97563A21} Adobe Utilities CS6
                      {4FFA83C0-007A-4DB3-955C-B5EEE73BEDAF} Adobe SwitchBoard 2.0
                      {50F00944-54F4-11E0-A154-19FB646A51FF} Adobe InDesign CS5 Application Base Files_7.0.4.553_AdobeInDesign7AppBase-mul
                      {50F5A7C9-1E43-4860-AED8-7F8722691F17} Adobe ExtendScript Toolkit CS6
                      {51C77DC1-5C75-4491-8645-A17CC33F5A36} AdobeColorEU CS6
                      {52B09838-E7B4-4D45-8D7D-FCB2F3910C9C} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul
                      {539AEF15-3A2B-4A31-A587-7E90F7D9C700} Camera Profiles Installer
                      {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5
                      {557F9FD3-EED8-43D7-AF29-0F19CA832728} AdobePDFL CS6
                      {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content
                      {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul
                      {5A39FDD0-686E-49BD-A6FF-02F7E8256DBF} Adobe Media Encoder CS5 PCI
                      {5A60CD44-B38B-47CD-BE38-219C81AE3345} Adobe ExtendScript Toolkit CS5
                      {5AF84E15-9A23-4295-8508-F2901A923E83} Adobe OnLocation CS5 Royalty Content_5.0.1_AdobeOnLocation5RoyaltyAll
                      {5C5F61E0-E13B-4FD6-9F4B-C034FFD0672A} Players For Adobe Flash Pro
                      {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live
                      {6025BAFC-3C31-4FA5-91A4-467E5478DAB2} Adobe After Effects CS5 Third Party Content Wrapper_10.0.2_AdobeAfterEffects10ProtectedWrapperAll
                      {620A6698-4868-444A-953F-26ABCF34F480} Adobe Fireworks CS5_11.0.2_AdobeFireworks11All
                      {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul
                      {627D49F9-9F71-436C-9B85-9ACAA9E78561} Adobe Media Encoder CS5 Dolby
                      {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing
                      {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All
                      {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support
                      {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension
                      {68489BE8-3960-11DF-8F88-C4A72C404F28} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US
                      {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US
                      {6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5
                      {6A75E573-6909-4D48-BDFA-D8ED118605A5} Adobe Illustrator CS5
                      {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack
                      {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper
                      {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll
                      {6D6FBE54-54F2-11E0-912B-47C4646A51FF} Adobe InDesign CS5 Application Language Files_7.0.4.553_AdobeInDesign7AppLang-en_US
                      {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral
                      {6F064E9A-480A-4B35-9765-533F8D3F472E} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll
                      {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5
                      {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5
                      {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul
                      {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5
                      {74EB3499-8B95-4B5C-96EB-7B342F3FD0C6} Adobe Photoshop CS6 Driver
                      {755A9707-8A74-4B18-A6FD-F80F5893BDF2} Adobe Fireworks CS5
                      {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack
                      {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1
                      {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content
                      {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB
                      {78E38D75-4D92-4F6E-B631-17A436BED680} AdobeColorVideoProfilesCS CS6
                      {78E50DF8-A115-42F9-B859-4F74903B0492} Adobe Premiere Pro CS5 Third Party Royalty Content_5.0.4_AdobePremierePro5RoyaltyAll
                      {796659A8-114A-4E16-9994-14DF6A1B1683} Adobe Utilities CS5
                      {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core
                      {7F7421AA-3A80-49B2-B88B-611A50C23D30} Adobe Bridge CS5_4.0.5_AdobeBridge4-mul
                      {800A369C-57B5-11DF-9E28-378C2C404F28} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul
                      {809CAFEA-B905-4940-8451-DBA0AE0AA825} Adobe Photoshop CS5 Core_12.0.4_AdobePhotoshop12-Core
                      {83463106-DD1C-4FE5-A61C-DF6715472AD4} Adobe Extension Manager CS6
                      {84901376-1C55-4BD3-AD2C-F9BDB4449DAC} PDF Settings CS5
                      {88878C42-AB99-4615-8B76-D5E783F174BF} Creative Suite 5 Master Collection
                      {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul
                      {8A5387E2-7F1A-4FDD-883F-511DC8AA2295} Adobe After Effects CS5 Third Party Royalty Content_10.0.2_AdobeAfterEffects10RoyaltyAll
                      {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5
                      {8D3FB5B0-395D-11DF-AEA7-642B2C404F28} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US
                      {9032BC04-1CB6-11DF-8041-A9C0CF51210B} Adobe Toolhints CS5
                      {9124DF4E-617D-486B-A970-8FA632244F24} Adobe Photoshop CS6 Core
                      {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule
                      {935FF832-3963-11DF-9CE8-97BA2C404F28} Adobe InDesign CS5 Application Feature Set Files
                      {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US
                      {977F44E9-6607-4C2D-A563-A383FAFFC406} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.4_AdobePremierePro5RoyaltyWrapperAll
                      {97BA0109-F6BE-4F50-8904-C19442D7216E} Adobe Bridge CS6
                      {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All
                      {9BE768D2-3963-11DF-B0A5-B7BA2C404F28} Adobe InDesign CS5 Application Base Files2
                      {9EEF9016-4356-11DF-9781-28A32C404F28} Adobe InDesign CS5 Application Base Files
                      {A0F72081-99FB-4FFA-AE1A-62B5A656CAC1} AdobeTypeSupport CS6
                      {A334FDED-DCCA-481E-B226-F902CCC419D2} Adobe Encore CS5
                      {A44863BF-8DB8-4D22-88DB-5A02BE319840} Adobe Linguistics CS5
                      {A4747434-3965-11DF-B081-A0842D404F28} Adobe InDesign CS5 Common Base Files
                      {A4EE8093-4250-4D8B-BDE4-A4675BB44953} Adobe Flash Catalyst CS5
                      {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5
                      {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US
                      {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport
                      {A9E40F78-E54D-494F-94A9-5D502F8DD1E1} Adobe WinSoft Linguistics Plugin CS6
                      {AA52817B-75CD-403A-90E1-6430ABD290E2} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.2_AdobeAfterEffects10RoyaltyWrapperAll
                      {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5
                      {AC85D480-BE25-4B01-84BE-E8A5932E39DB} Adobe Hunspell Linguistics Plugin CS6
                      {AD7623FD-F90A-4181-A37C-63342ACC3FA7} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul
                      {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper
                      {B198547F-579A-4CE1-AC61-558130922957} Adobe Flash Builder 4
                      {B220D6EB-574A-4B6A-948C-135111076BBD} Adobe Premiere Pro CS5_5.0.4_AdobePremierePro5AllTrial
                      {B4975576-60AD-4181-AED4-253FC150B404} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack
                      {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack
                      {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content
                      {B98E0DCB-1A75-4394-9813-3A114AA3891D} Adobe Mini Bridge CS6
                      {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5
                      {BB66788C-4C4F-4EB0-B146-9178857DE287} AdobeColorNA CS6
                      {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5
                      {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content
                      {C21384F7-1A36-4706-95AB-B09BCE3C144F} Adobe Premiere Pro CS5
                      {C7B1C1B3-368D-4C32-A818-83F1554EB398} AdobeColorCommonSetRGB CS6
                      {C7BDD22E-AD27-4B06-BEB9-F97BC4D89671} Flash Player
                      {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth
                      {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets
                      {CD01AE7A-54F4-11E0-B795-6709656A51FF} Adobe InDesign CS5 Application Base Files2_7.0.4.553_AdobeInDesign7AppBase2-mul
                      {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content
                      {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels
                      {CE85218E-3276-4952-B872-A06C6C9C9C1E} Adobe Dreamweaver CS5_11.0.4_AdobeDreamweaver11en_USLanguagePack
                      {CFC3110A-491C-4DBF-A97D-66C567600A2F} Photoshop Camera Raw 7
                      {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5
                      {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5
                      {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5
                      {D6A4C9B1-5AE2-4118-AD9D-24313C79F2B6} Adobe Photoshop CS5 Support_12.0.4_AdobePhotoshop12-Support
                      {D7EC9AC4-B2A7-48D5-8555-CB6FF029EAF7} Adobe Media Encoder CS5_5.0.1_AMECore5All
                      {DA1B174B-4297-467C-9EF8-0AB8D4D5171E} Adobe After Effects CS5
                      {DC541ECE-2FFE-11DF-823C-BF762D404F28} Adobe Buzzword CS5
                      {DD5B1FAF-47FA-4B6D-A31C-5E313EB0DD07} Adobe Dreamweaver CS5
                      {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs
                      {DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D} Recommended Common Fonts Installation
                      {DE88AA40-6766-43D3-A755-8FC374B3D2C3} DynamiclinkSupport
                      {DEAE3F15-7C11-41EC-8AE9-204F64E1014D} Adobe Fireworks CS5_11.0.2_AdobeFireworks11en_USLanguagePack
                      {E489B5E9-5646-4F0D-89E3-FF9E4A27DF1B} Adobe Dreamweaver CS5_11.0.4_AdobeDreamweaver11-mul
                      {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5
                      {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack
                      {E8B1DAAA-0B6B-44E6-A2D3-8E418EA0EA85} AdobeCMaps CS6
                      {E9047020-446C-4C64-8477-E52ACD204DEE} Adobe Media Encoder CS5 PCI WRAPPER_5.0.1_AMEPCIWrapper5All
                      {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6
                      {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro
                      {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs
                      {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5
                      {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack
                      {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support
                      {F8918124-1CFB-4AB9-9BC2-39B961DBBBEE} Pixel Bender Toolkit
                      {FFEDE6AE-3052-11DF-89B7-E7102C404F28} Adobe ReviewPanel CS5
                      [       0] Fri Aug 24 08:33:05 2012  INFO
                      ______ Verifying payload integrity ______
                      Checking for payloads having same family and product names but different adobe codes
                      ______ Verifying payload integrity : Passed ______
                      Operation order summary:
                      When distributing payloads across media, the following order must be preserved, except that
                      adjacent payloads with the same mediaGroup can be re-ordered across media boundaries without introducing
                      extraneous media swaps for the user.
                      :: END TIMER :: [CreatePayloadSession] took 3017 milliseconds (3.017 seconds) DTR = 6.6291 KBPS (0.00647373 MBPS)
                      *** Checking patch payload : {C24D91B7-406B-4C50-879A-44478359B772}
                      installDBPath : /Volumes/AdobeExtensionManager-5.0.2-mul-AdobeUpdate/payloads/AdobeExtensionManager5.0All -011211025639/Install.db
                      Successfully Opened installDB
                      Payload is not customized
                      Parent AdobeCode : {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
                      Parent Installation directory : /Applications
                      [       0] Fri Aug 24 08:33:06 2012  INFO
                      [       0] Fri Aug 24 08:33:06 2012 DEBUG
                      Requested action "install" for {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0
                      Using installer mode 1
                      ::START TIMER:: [Setting Payload Actions]
                      PayloadPolicyInit: BEGIN Updating installstate for payloads
                      PayloadPolicyInit: END Updating installstate for payloads
                      PayloadPolicyInit: BEGIN Creating policyNodes
                      PayloadPolicyInit: END Creating policyNodes
                      PayloadPolicyInit: BEGIN Calculating initial graph
                      PayloadPolicyNode._SetPayloadAction: repair for {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0
                      PayloadPolicyNode.SetAction: FN->FY for {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0
                      PayloadPolicyNode.ComputeConstraint: Static installMode 1 mode constraint is 2 12, Y for {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0
                      PayloadPolicyNode.SetAction: IY->IY for {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0
                      PayloadPolicyInit: END Calculating initial graph
                      Setting action for {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0 per deployment file.
                      :: END TIMER :: [Setting Payload Actions] took 1 milliseconds (0.001 seconds) DTR = 4000 KBPS (3.90625 MBPS)
                      ::START TIMER:: [SimulatePayloadOperations]
                      Creating instruction for payload {C24D91B7-406B-4C50-879A-44478359B772} Adobe Extension Manager CS5_5.0.2_AdobeExtensionManager5.0All 5.0.2.0
                      [       0] Fri Aug 24 08:33:06 2012  WARN
                      :: END TIMER :: [SimulatePayloadOperations] took 154 milliseconds (0.154 seconds)
                      Opened installation queue
                      [       0] Fri Aug 24 08:33:08 2012  INFO
                      [       0] Fri Aug 24 08:33:08 2012 ERROR
                      :: END TIMER :: [Total Timer] took 12211 milliseconds (12.211 seconds) DTR = 378.02 KBPS (0.36916 MBPS)
                      • 8. Re: "Not a Valid Signature" after installing the patch.
                        Hi Kemch,
                        From your log, we found following errors:
                        It means the patch installer found that you already have 5.0.2 patch installed, so the patch could not be installed again, although you still got the wrong version number 5.0.334. One possible solution is, install Extensoin Manger CS5( http://www.adobe.com/exchange/em_download/em50_download.html ) in another Mac10.7 device, and then installed Extenion Manager CS5.0.2 patch( http://download.macromedia.com/pub/dw_exchange/extension_manager/mac/AdobeExtensionManager _5_0_2_mul_AdobeUpdate.dmg ). Then copy "/Libary/Application Support/Adobe/Extension Manager CS6" to your Mac to replace the Extension Manger you installed. After that, you can lauch Extension Manger to see if it works.
                        • 9. Re: "Not a Valid Signature" after installing the patch.
                          kemch1013 Level 1
                          Thank you that worked. Luckily I had a colleauge with the same system setup. The path you said to copy did not exist, but I'm assuming you meant the actual application itself, which was /Applications/Adobe Extension Manager CS5
                          Thanks again.
