5 Replies Latest reply on Aug 22, 2012 11:34 PM by Flex harUI
    Fonts Problem
    flex_star
           Hi All
             For my web application i have to use more than 200 fonts. Currently i am embeding it through flash and using that swf. but this way for embedding makes the main,swf size bigger .
      I am using style manager to load that swf at run time .
      StyleManager.loadStyleDeclarations("assets/style/basic.swf");
        Is this the correct way to use fonts for web app or any other way pls help me.. Im in trouble
        • 1. Re: Fonts Problem
          Flex harUI Adobe Employee
          Most folks load individual fonts via loadStyleDeclarations or as regular modules.  Neither should be inflating the main swf in any significant way.
          • 2. Re: Fonts Problem
            flex_star Level 1
            Hi..
                If any examples please provide (it might be more helpful).. right now i am loading fonts through embedded swf via flash cs4 .
                 The fonts should load like this
            http://www.ooshirts.com/t-shirt-design-lab.html
            • 4. Re: Fonts Problem
              flex_star Level 1
              Thanks a lot ... I have been using same way to load fonts ...
              My another clarification is there.... right now i am assigning these fonts for RichEditable Text  but Same way i used the fonts for UITextfield but these fonts are not supporting.
              For UItextField I am assigning fonts through Textfomat.
              I am Embedding font in swf
              [Embed(source = "assets/fonts/arcfont.swf", fontName = "Arial")]
                                  private var Arialcls:Class;
              By using the Arialcls
              var str:Object            =   new Arialcls().fontName;
              public var _textFormat:TextFormat;
              _textFormat.align     = TextFormatAlign.CENTER;
                                                      _textFormat.font    = str;
                                                      _textFormat.size    = _fontsize;
                                                      _textFormat.color  = _fontColor;
              After assigning fonts to textfomat i am assigning to UiTextField
              var field:UITextField  = new UITextField();
              field.defaultTextFormat  = _textFormat;
                                            field.embedFonts                     = true;
                                            field.setStyle('embedAsCFF',false);
                                            field.multiline                      = false;
              but instead i need to load fonts loaded dynamically through
              for  UITextField...
              Pls Help it ll be useful for me a lot
              • 5. Re: Fonts Problem
                See the embedded fonts article on my blog.
                Alex Harui
                Flex SDK Team
                Adobe Systems, Inc.
                http://blogs.adobe.com/aharui
