1 Reply Latest reply on Aug 26, 2012 4:18 PM by Sham HC
    Regarding inheritance in adobe day cq
    Heidi albert
      I am fairly new to adobe cq...
      I came across inheritance in the documentation....I did not understand the difference between disable inheritance and cancel inheritance....
      I applied disable inheritance but the child pages still inherited the parent page images which was put in the inherited paragraphs.....
      Could anyone please help me...
      Thanks in advance...
      Regards,
      Heidi
        • 1. Re: Regarding inheritance in adobe day cq
          Sham HC Level 7
          HI Heidi,
            I beleive your understanding is correct & agree the name is slight confusing This difference is not clear however reading the label descriptions of the checkbox carefully will help to clear configuration.  Documentation at [1].
          Just to demonstrate let us use geometrixx example. In author instance
          *    Go to http://<host>:<port>/content/geometrixx/en/products/triangle.html
          *    On the right side you would see iparasys, Select "" & save.
          *    Go to http://<host>:<port>/content/geometrixx/en/products/triangle/overview.html
          *    You would see it is not inherited & if you are in edit mode you would see "Parent canceled inheritance"
          For second case
          *    Go to http://<host>:<port>/content/geometrixx/en/products/square.html
          *    In Iparasys Select "Disable Inheritance" & save.
          *    IN edit mode you would see "Inheritance disabled" & in preview mode not inherited from the parent page.
          [1]   http://dev.day.com/docs/en/cq/current/wcm/default_components.html#Inheritance%20Paragraph% 20System%20%28iparsys%29
          Sham
