2 Replies Latest reply on Dec 7, 2012 2:17 AM by baydream112
    Printing dialog box: "unresolvable conflicts"
    chirrchirr Level 1
      I'm attempting to set up my new MacBook Air to print out  a custom envelope size on  my Brother HL-5340D  –  something I've done successfully with my office computer (a black MacBook with OS X 10.6.8). After creating a print preset in the InDesign printer settings, I am having trouble getting access to the some of the more idiosyncratic printer settings (toner fixing, for instance). I keep running across this message: "Changing 'Media Type' to 'Plain Paper' would cause an unresolvable conflict with the selected custom paper. No change will be made."  Additionally, I am having trouble with reaching the advanced settings under the "Print Settings" menu of the standard Apple print dialog box (which encompasses the Brother-specific drivers). If I attempt to change the "Improve Print Output" settings I get a similar message: "Changing 'Improve Print Output' to 'Improve Toner Fixing' would cause an unresolvable conflict with the selected custom paper. No change will be made.'
      I'm imagining there is some conflict between InDesign's printer settings (which I understand Adobe recommends InDesigners use whenever possible, but there are neither "media type" nor advanced print settings in the InDesign print dialog box), and I've compared the printer settings on my black MacBook (the one correctly printing) to my MacBook Air and I can't figure out the difference. The only suspicion I have is it seems that the black MacBook's printer settings in InDesign are somehow overriding the Apple/Brother presets, whereas on my Air, that's not happening – I've created a pre-set specifically for the custom envelope printout to complement (or so I thought, anyway) the settings that I could not reach from within the Adobe box. Back in Adobe's printer settings, for instance, the "Custom Size" option for paper is greyed out, so there are certain options that it seems I must access from the Apple/Brother drivers.
      Does anyone have any suggestions or best practices that I might adopt to avoid this conundrum? I have screenshots, but it seems they can't be attached anymore. Here's the printer summary. Thanks everyone, Quin…
      Print Preset: [Custom]
      Printer: Brother HL-5340D (green)
      PPD: N/A
      PPD File: N/A
      General
          Copies: 1
          Collate: N/A
          Reverse Order: Off
          Pages: All
          Sequence: All Pages
          Spreads: Off
          Print Master Pages: Off
          Print Layers: Visible & Printable Layers
          Print Non-printing Objects: Off
          Print Blank Pages: Off
          Print Visible Guides and Baseline Grids: Off
      Setup
          Paper Size: Defined By Driver
          Paper Width: 3.13 in
          Paper Height: 5.5 in
          Page Orientation: Portrait
          Paper Offset: N/A
          Paper Gap: N/A
          Transverse: N/A
          Scaling: 100%
          Constrain Proportions: On
          Page Position: Upper Left
          Thumbnails: Off
          Tiling: Off
      Marks and Bleed
          Crop Marks: Off
          Bleed Marks: Off
          Registration Marks: Off
          Color Bars: Off
          Page Information: Off
          Printer Mark Type: Default
          Crop Mark Weight: 0.25 pt
          Mark Offset from Page: 0.0833 in
          Use Document Bleed Settings: On
          Bleed Top: 0 in
          Bleed Bottom: 0 in
          Bleed Inside: 0 in
          Bleed Outside: 0 in
          Include Slug Area: Off
      Output
          Color: Composite RGB
          Text As Black: On
          Trapping: N/A
          Flip: N/A
          Negative: N/A
          Screening: N/A
          Simulate Overprint: Off
      Graphics
          Send Data: All
          Download: N/A
          Download PPD Fonts: N/A
          PostScript®: N/A
          Data Format: N/A
      Color Management
          Document Profile: sRGB IEC61966-2.1
          Color Handling: Let InDesign Determine Colors
          Printer Profile: Document RGB - sRGB IEC61966-2.1
          Preserve RGB Numbers: Off
          Proof Profile: N/A
          Simulate Paper Color: N/A
      Advanced
          Print &as Bitmap: On
          Bitmap Resolution: 600
          OPI Image Replacement: N/A
          EPS: N/A
          PDF: N/A
          Bitmap Images: N/A
          Transparency Flattener Preset: N/A
          Ignore Spread Overrides: N/A
