1 Reply Latest reply on May 13, 2006 2:41 AM by Jesus Iglesias
    DataField on custom DataGrid Itemrenderer
    Jesus Iglesias
      Hi again,
      I have one datagrid with one custom column. I define de itemrenderer and its ok.
      Now I need to know the Datafield for that column within the itemrenderer, but I don´t know how to, nothing seems to work.
      Please help me, How can I now the properties of a column whitin a custom itemrenderer?
      This is how I create the column on runtime
      var col:DataGridColumn = new DataGridColumn("Monday");
      col.itemRenderer= new ClassFactory(celdaEstadoHabitacion);
      col.dataField=i.toString();
      Then I need DataField and colName.
      I tried something like
      col.myfield="field";
      and on the itemrenderer make a bindable "myfield" variable, bur it returns ther is no property whith "myfield" name.
        • 1. Re: DataField on custom DataGrid Itemrenderer
          Jesus Iglesias Level 1
          Hi again,
          I finally found the solution. In my renderer I doon't know the datafield name cause I don't know how many columns I have, are dynamic, and datafields are "1", "2", "3".. and so on.
          Solution. As my renderer extended from canvas and it does not implement IDropInListItemRendere, i have to make it implents and then create get/set listData methods, then all is easy:
          <mx:Canvas xmlns:mx=" http://www.adobe.com/2006/mxml" xmlns="*" doubleClickEnabled="true"
          implements="mx.controls.listClasses.IDropInListItemRenderer">
          <mx:Script>
          <![CDATA[
          import mx.controls.dataGridClasses.DataGridListData;
          import mx.controls.listClasses.BaseListData;
          import mx.events.*;
          private var __listData:BaseListData;
          [Bindable("dataChange")]
          public function get listData():BaseListData{
          return __listData;
          public function set listData(value:BaseListData):void{
          __listData = value;
          dispatchEvent(new FlexEvent(FlexEvent.DATA_CHANGE));
          </mx:Script>
          </mx:Canvas>
          Now you can make your script access
          var data as DataGridListData =__listData as DataGridListData;
          And data is the standard data from an itemrenderer.
