1. Re: Changes not reflecting in publish server
Yogesh Upadhyay Aug 22, 2012 10:16 PM (in response to Hina29)Hina,
As a sanity check please make sure that,
1) Component is activated to publish instance with all required JS by using crxde light
2) there is no JS error in publish.
Yogesh
2. Re: Changes not reflecting in publish server
Hina29 Aug 22, 2012 11:44 PM (in response to Yogesh Upadhyay)I have activated all the required js but still it is not reflecting
3. Re: Changes not reflecting in publish server
Satish@pune Aug 23, 2012 10:43 AM (in response to Hina29)Dear Hina,
You need to delete below folder from publish instance -
Go to Publish Instance , login with credential
open content folder then delete your content folder of your application - content/<your content app>
then
open var/classes/..../jsp/<your app code> and delete your application which is crated in var folder
then restart your server.
Hope it will work......
Regards,
Satish....
4. Re: Changes not reflecting in publish server
Yogesh Upadhyay Aug 23, 2012 10:55 AM (in response to Satish@pune)There is no need to restart server. What version of CQ are you using ? I remember some JSP compilation issue in publish instance if JSP files get modified. But it was fixed in CQ5.5 update1. Also restarting JSP/sling classloader (org.apache.sling.commons.classloader and org.apache.sling.jcr.classloader) should trigger force recompilation.
Also since you mentioned you are clearing cache. From where are you trying to access changes ? Dispatcher or publish instance ?
Yogesh
